07-15-2013, 01:59 PM | #1 |
Rep 3,290
Offset and tire clearance
We are running 205/50-17 on 8x17et35 wheels. That fits without rubbing.
I will install some BBS RX 8x17et38 wheels, and I am considering 225/45-17 tires this time. Will that fit as well? I have noticed that the stock 225-fitments are running with et43, so this will bring the tires 5 mm closer to the wheel arches. I think it will fit, but it would be nice if somebody else has some experience and can confirm it. |
07-16-2013, 03:58 AM | #2 |
BMW fanatic
15
Rep 43
et43 with 8" rim? Sure no problem at all.
BMW F2X/F3X Open Group
http://www.facebook.com/groups/bmwf20hkg/ |
07-16-2013, 04:39 AM | #3 |
Rep 3,290
07-24-2013, 02:27 AM | #4 |
Rep 233
Kinda bumping the thread here..
I'm running 19x8.5 ET40 in front (225-35) and 19x9.5ET45 in the rear (255-30). It also all depends on the type of tyre you're running. Some are less high or less wide than others. I have Falken FK-453's who are known to be a smaller tyre, as the sidewalls don't really go straight up as with e.g. a Michelin PS Oh yeah, I'm all around under high load. and I have KW V1 lowering (about -5cm) |
07-27-2013, 04:56 AM | #6 |
Rep 2
Hi guys!
I have a set of 17" 157 style wheels with et34 and 225/45/17 RS3 hankooks. On the road it seems to be no problem with the clearence. But on a track, sidewalls were rubbing the wheel arches. Now I'm running et40 wheels with 235/45/17 and it seems pretty good. By the way i have m sport suspension. Both wheels are 8 inch wide. |
07-31-2013, 08:41 AM | #8 |
Rep 3
Hi all, I really need help here.
I'm buying a F20 118i(non M sport kit), and will come with 16" and ET40 wheels. I want to put Beyern Multi 18" wheels, but I'm not sure if the fitment is possible: Front: 18X8.5 ET40 with 225/40-18 or 235/40-18 Rear: 18X9.5 ET45 with 255/35-18 Few questions: 1- In the front 225 tires with 8.5 inch will look stretched? I don't like stretched look, but I´ve afraid that 235 will rubbing. 2- In the rear is worst, 9.5 I think is too much and with 255 will rubbing inside or outside? Remembering the offset is high, ET45. I can buy for rear the same as the front, 8.5 width, but I prefer staggered, my actual E81 have M Sport kit and factory staggered wheels. What do you think about this unusual set fitment? I´m from Brazil and I need to import from US this wheels, if eventually didn't fit, I couldn't change it. Other information, I will not lower the car. Thanks in advance. Regards, Fabio Last edited by CmteFabio; 07-31-2013 at 09:29 AM.. |
07-31-2013, 04:49 PM | #10 |
Rep 3
A little stretched is not a problem, the real problem to tell the truth is the ET40, I have doubt that fits, and the 9.5 inch rear wheels with ET45 too.
Making a research today, I found a store in UK that sells Beyern: http://www.rimstyle.com/alloywheels/...ulti&year=2013 I made this because in Europe sites have F20 beyond the cars application, in US doesn't exist. For this site, when we select a F20 and 18 staggered set that I looking for, they send together a 3mm spacer for rear wheels to better fit, maybe my doubt was answered here, if the site was right, I need a pair of 3mm spacers too. Thank you, if somebody knows something more about this set and could help I will appreciate very much, is hard to find informations about the wheel fitment in F20. |
07-31-2013, 05:22 PM | #11 |
Rep 3,290
I recommend looking at the wheel sets directly from BMW, what offset they have.
You find them in the online ETK: http://realoem.com/bmw/select.do?kin...ies=F20&arch=0 |
10-21-2018, 08:44 AM | #13 |
Rep 2
Looking for some help. Brought some wheels for winter and didn’t check the ET (my bad), so have a staggered set of Fronts 7.5Jx18 ET49 & backs 8.5Jx18 ET52 and putting ContiWinterContact TS 830 P 225/40R18 92 V RUN ON FLAT Tyres on them. I believe the backs are OK.
Anyone know if the fronts will fit and/or damage anything? |
10-21-2018, 02:18 PM | #15 |
Rep 8
I'm also trying to get the best fit wheels, found a very useful link where all the variables can be seen in a graphical way.
https://www.wheel-size.com/calc/
BMW 118i F20 B38
