10-21-2017, 10:51 AM | #1 |
Rep 37
Help. Retrofit 8.8 inch screen
Hello my dear friends, i have a bmw 116D f20 lci, from 2016... and i have some questions about the bigger screen.
Is it possible for me to fit the 8.8 screen? I've seen it on f30 and some tutorials about it but only for the f30... i know i have to code it, to get the screen the proper resolution and etc... What do i need to buy besides the screen itself? I need to buy the original one right? Or do i need to buy a chinese-kind to do it? I tried to do some searches but i can only find stuff really outdated and i dont want chinese poor quality you know? Best regards!! [EDIT] Btw i have the professional bmw radio - 663 Code |
10-21-2017, 12:52 PM | #2 |
Rep 104
Hi,
This has been discussed many times before. The process is the same as F30. You will need NBT head unit , 8.8" screen, controller, gps antenna. Online shops are already selling these parts as a kit. No need to but seperately. |
10-21-2017, 03:32 PM | #3 |
Rep 37
As you saw on my post i talked about the f30 posts... and i wanted to check if the process was the same... so the budget is 1k+?
If you can adress me to a post with the tutorial or something like that would be great |
10-21-2017, 05:04 PM | #4 |
Rep 104
I will pm you a few topics.
Note: you WILL need an emulator or a generated license code for the head unit to work otherwise it will block itself when you connect it to your car. |
10-21-2017, 05:37 PM | #5 | |
Rep 37
Thank you for the response, so its actually the Head Unit, display and a gps antenna ? And also coding of course Holy hell, im new to all of this... im old school, like when we needed to change the head unit and it was just needed an adaptor, and do some wiring you know? Ahahaha Even in my Clio 3 Rs all of this was very easy |
10-22-2017, 06:30 AM | #6 |
Rep 104
yeah it needs to be coded to your car's VIN in order to work. I personally got help from a aftermarket shop that retrofits these parts, so I can't help you out about coding and emulator part. However, basically yes emulator just fakes your car's control unit to pretend like that part belongs to your car. second way to achieve this is to buy or generate a license code online and code it yourself. pretty sure a litte bit research on that issue will get you some results. good luck
