BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Any mate install F80 lower control arm on a 116/118i?
      03-04-2016, 11:51 PM   #1
lefthander
Drives: BMW F30
I read BP thread and it's seem like it can be fix on the f20 rwd m135i which has a different control arm part number than a regular 116/118i.
http://www.realoem.com/bmw/enUS/show...diagId=31_0942
The USA boys had the lower control arm fixed on a F22 228i and it shared the same part number as the 116/118i. So can I assume it can be fix on a regular f20 116/118I?
http://www.realoem.com/bmw/enUS/show...diagId=31_1098
Last but not least, how much -ve camber increase we will get from the lower control arm.
Any help would be grateful!
      03-05-2016, 02:39 AM   #2
Bee Pee
Drives: AW M2 DCT
Lower control arms add about an extra 1deg of negative camber to front wheels.
Compared to 116/118, Mx35i comes -0.5 swivel bearing housing as std which could be an upgrade to your car if you want to add less negative camber.
My car (m135i with lowered springs and M4 LCAs) is running -2deg which is about the most I would run on a road car.
Finally if running running 17" wheels or less, be careful to ensure that LCA upgrade will clear the inside edge of the wheel. No issues with 18" and above alloys.
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      03-05-2016, 03:29 AM   #3
lefthander
Drives: BMW F30
Thanks BP, when I check my pivot/swivel bearing housing, seems like there's 2 options available as well.
http://www.realoem.com/bmw/enUS/show...diagId=31_0954
I vividly remember on my stock car alignment, i got 0.5 degree -ve camber, does that mean I will get 1.5 degree -ve camber on it with LCA? I don't mind running -1.5degree but -2 is way too aggressive for a road car. Lol
      03-05-2016, 04:56 AM   #4
263
I ran -3 up front and -1 in the back of my E30 318iS road car! :-)
      03-05-2016, 07:14 AM   #5
lefthander
Drives: BMW F30
      03-05-2016, 11:56 AM   #6
yalim7
[HOONIGAN]
yalim7's Avatar
Turkey
Drives: F20 118i-E93 335i
They fit without any problem. I have them on my pre-LCI 118i with lowered springs. Like BeePee, I have -2deg up front and I've never experienced any problems about it being too aggressive for road. FYI, they also give a remarkable amount of caster angle
When you feel like life is passing you by, downshift.
      03-05-2016, 12:02 PM   #7
lefthander
Drives: BMW F30
Thanks! I am on 18" wheel with front 225/40R18 tyres with offset 45 and lowered with AC Schnitzer suspension. Wonder if I will get any sort of rub from the LCA?
What tyres size and offset are you on?
Cheers!
      03-05-2016, 02:06 PM   #8
Bee Pee
Drives: AW M2 DCT
Why ?
Is that opinion or if based on fact, please elaborate ?
AW M2 DCT
      03-05-2016, 03:20 PM   #9
yalim7
[HOONIGAN]
yalim7's Avatar
Turkey
Cheers!
I have the same setup as yours for winter and 40 offset wheels with same tyre size for summer and no rubbing with both. I don't think you will rub with that setup and suspension unless you go too low with coilovers or something
      03-06-2016, 04:37 AM   #10
lefthander
Drives: BMW F30
Thanks. I will give it a go...
      03-06-2016, 04:38 AM   #11
lefthander
Drives: BMW F30
Originally Posted by Bee Pee View Post
Why ?
On my Scooby years ago, I run -ve 2 degree and tyres wear was a pain.
So probably my own bad experience.
      03-06-2016, 08:48 AM   #12
Bee Pee
Drives: AW M2 DCT
Ive been running -2deg and it's helping to save soft outer shoulder of mpss as getting even tyre wear across width of the tyre so combo of the geometry and mpss works fine for m135i
AW M2 DCT
      03-06-2016, 10:28 AM   #13
lefthander
Drives: BMW F30
Cheers mate.... Appreciated...
      03-24-2016, 08:04 PM   #14
lefthander
Drives: BMW F30
I got the lower arm fixed and zero out the toes. Car felt twitchy but turn in and corners is a breeze. What's the toe you guys are running?
      03-26-2016, 03:56 PM   #15
Bee Pee
Drives: AW M2 DCT
Zero toe.
      03-26-2016, 05:39 PM   #16
yalim7
[HOONIGAN]
yalim7's Avatar
Turkey
I can't remember the toe but will get an alignment soon with the coilovers. I will share the numbers after.
      04-02-2016, 12:57 PM   #17
yalim7
[HOONIGAN]
yalim7's Avatar
Turkey
Had an alignment today. Zero toe like yours with -1.85 camber and 7.45 caster angle.
