BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > F20 Brake Drying Function
      08-14-2020, 01:43 AM   #1
NigeeNooNoo
Drives: 2013 F20 120d X-Drive
Apologies if this has been discussed previously. I recently bought a 2013 F20 120d which appears to have the brake drying function. I've had beamers before but never with this so was a little worried when I first experienced the braking until I twigged what it was. However the braking has become severe especially when motorway driving in the wet so much so it reduces the speed by 10-20 mph and I'm now concerned someone will run into the back of me. My question is - can this feature be coded out ?
      08-14-2020, 06:46 AM   #2
No one
Drives: F21 118i
Here's a thread on this issue: M135i 2013 - Brakes coming on every 30 secs in WET!.
      08-14-2020, 10:37 AM   #3
NigeeNooNoo
That's great thanks. Looks like it can be coded then (at least to a low setting). Is this a Bimmercode type fix or more pro support required?
      08-15-2020, 12:35 AM   #4
No one
Drives: F21 118i
More pro support required. Take it to a service.
      08-15-2020, 11:38 AM   #5
NigeeNooNoo
Can anyone recommend specialist close to Lancaster?
      08-15-2020, 02:24 PM   #6
No one
Drives: F21 118i
I guess you should take this question to the 3 Series forum (it's much more populated and the models are close): https://f30.bimmerpost.com/forums/fo...play.php?f=429.
