08-11-2020, 05:54 PM | #1 |
Rep 11
F20 116d handling upgrades
Hi,
I'm a new user here and I recently brought a BMW f20 116d from 2015. I have VSS steering and I'm quite disappointed how the car handles... steering feels filtered and light/over assisted on high speeds. On turns I really feel body rolling - like my old GOLF IV. I'm really looking forward to improve all of this asap. From what I've researched on other forums, these are the cheapest top priorities: 1. Rear Underbody brace; 2. Rear subframe bushes; 3. New Front Sway bar; 4. Bilstein B4. I'm also considering upgrading my 16" wheels to bigger 17" but I don't know if this will improve car handling. Please let me know what you think of this and if you have other suggestions. Thanks! Last edited by evildream; 07-14-2021 at 08:06 AM.. |
08-12-2020, 01:05 AM | #2 |
Rep 3,290
Based on my experience with the F20 M-Sport and track days, I would take a different approach. If think the handling is pretty good already, but to improve it, my number one priority would be M4 front control arms, to get more negative camber up front. Number two would be sporty tyres, like Michelin Sport Cup 2. Number three would be a set of coilovers to stiffen the suspension up.
If you don't have sport suspension on the car, you may want to add coilovers first, along with M-Sport swaybars. Bilstein B4 is not really a performance upgrade, but a product with pretty much the same characteristics as the stock dampers. If the stock bushings are worn out, it would make sense to replace them, otherwise I think they are pretty good. I don't think a brace would be needed either. |
09-04-2020, 01:53 PM | #5 |
Rep 16
What i did to my 116d is weichers top strut bar, poly sway bar bushes, M-Tech rear underbody upgrade kit, hartge lowering springs, these relative cheap upgrades makes the car alot better, cornering at high speed is now so much fun 😂👌i have also done a remap to 190hp/400nm and upgraded brakes to 125 brakes (312 front/300 rear and now ventilated in the rear too)
06-04-2021, 07:04 PM | #6 | |
Rep 331
Drives: M140i F20 LCI-2
LCA + TS vs Camber Plates
I suggest examining the use of Vorshlag or Millway Camber plates as 1 or 2 degrees extra negative camber would save the outer edge of front tyres and give more even wear.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. |
06-22-2021, 11:45 AM | #8 |
Rep 3,290
06-26-2021, 03:36 PM | #9 | |
Rep 11
Great! This is exactly the approach I'm looking for. Do you have 17" wheels? I'm going to upgrade wheels first, then: - Eibach pro kit springs (with OEM shocks) - Rear underbody kit - underbody front sway bar (m-sport) I'm not going to replace the OEM shocks for now. About strut bar vs sway bar, I guess the sway bar would be better to prevent body roll? |
06-26-2021, 04:40 PM | #10 | |
Rep 3,290
Make sure to get some good tyres when you upgrade the wheels. |
06-27-2021, 08:50 AM | #11 |
Rep 11
Thanks.
Can you please tell me if a front m sport sway bar will fit on a regular F20? Just received a reply from an eBay seller stating that it is not compatible? Can anyone share the part number? About tyres, I'll definitely fit Contis which I'm a great fan of. |
06-27-2021, 09:10 AM | #12 | |
Rep 1,340
He means Michelin. |
06-28-2021, 03:07 AM | #14 |
Rep 11
06-28-2021, 12:47 PM | #15 | |
Rep 1,340
Again, I don't know/care what's "old" or "new" there, but on this forum people agreed Michelin "whatever" Sport were the best performance ones as well, I recall. |
06-29-2021, 09:10 AM | #16 |
Rep 11
About rear subframe bushes, is this mod worth it to improve handling?
Mine being a 116d with a standard suspension setup (soon upgraded). From what I've read, there's no consensus. I guess it really depends on your atual setup. |
06-29-2021, 10:35 AM | #17 | |
Rep 1,340
And by the way, when I suggested Michelin tires I thought you were going up from 17" wheels. There are no Michelin Sports for 17". |
06-29-2021, 02:51 PM | #18 |
Rep 3,290
06-29-2021, 04:45 PM | #19 |
Rep 11
06-29-2021, 04:53 PM | #20 |
Rep 1,340
I checked it twice back in time, recently as well. My impression was there was nothing at all. Now again (factory/summer "mixed" set of 225/45 R17 91W + 245/40 R17 91W, hardly any options for the rear even "in theory" ): Pilot Sport 4S, "Latest generation" on US Michelin site , Pilot Sport 4 on the local Michelin site but not actually available at any local official dealer currently. So it like depends on the location. And the rears width.
07-14-2021, 08:03 AM | #21 |
Rep 11
Just got hold of two parts numbers for springs, compatible with my car, which I assume are MSport (and not MPerformance). Can anyone confirm?
front: 3133 6851922 / rear: 3353 6851929 I'm undecided between these (which are stiffer than standard and lower the car only around 10mm) and Bilstein Prokit (lower around -20mm) which standard shocks... opinions are welcome |
12-19-2021, 06:41 AM | #22 |
Rep 11
Upgrades finally completed. Now I have a car that handles like a proper BMW.
The upgrades that I did for now: * Rear Underbody brace; * Bilstein Pro Kit Springs (with OEM shocks); * 17" Wheels from Sport line edition It now has a harder ride and steering feels way stiffer and connected. The car now handles much better, the boat feeling I had when turning is almost gone. I'm also not satisfied with brake sensitivity... they are too soft and don't bite like VW cars... after reading a few posts, I'm planning to upgrade pads to Brembo let's see how it goes... Don't know if upgrading brake fluid makes any difference on this, I guess it only helps with brake fatigue but i'm open to opinions. |
