BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > 2014 116i misfire n13
      02-11-2023, 02:01 AM   #1
Js116i
Drives: BMW f21 116i
Hi all!
Sorry i know this has been covered many times before but I'm failing to get to the bottom of it. I have read every post relating to misfires.
My 2014 n13 116i with 38k miles has a misfire but if driven gently shows no fault codes. These only appear after giving it a fair bit of throttle making the car misfire and shake badly then the drivetrain fault appears along with all the fault codes most of which relating to cylinder 4.
The car had been parked up and left for 4 years before I bought it with a suspected timing chain issue even though it sounded fine - I had this changed anyway when I bought it.
Fault codes were
140010
140410
140001
140401 (all of these were relating to misfire cyl 4)
801C20 - ZGM central memory full - no control - unit fault
Its just had new battery, ngk iridium spark plugs, knock sensor, full service, timing chain and 4 'used' injectors.
The fault codes were mostly relating to cylinder number 4 misfire but when i swapped plugs and coil packs around the fault didn't follow to a different cylinder.
The garage had the car to do a compression test and since having it back it now says cylinder number 1 misfire instead of 4.
They have suggested replace all coil packs with quality bosch items and getting 4 bosch spark plugs to match.
I'm hesitant to do this though as when the plugs and coils are moved around the fault doesn't move. How it has moved from 4 to 1 since they have done compression test has baffled me.
Anyone have any ideas please? I'm at my wits end and don't want to throw money blindly at it.
Thank you
      02-11-2023, 05:02 AM   #2
IJO
Drives: BMW 116I F20
Unplug the maf sensor but could be a coil pack failing under load.
      04-14-2023, 06:15 PM   #3
Jajatu
Drives: 116i
Have you tried to use the original coils? Are not really expensive.
There is any vacuum leak? My PCV was out of place and I had missfirings till I stoped and put in place again
      09-06-2023, 11:02 PM   #4
Wellingtonz
Drives: bmw 118i f20 n13/ 320i F30 N20
Originally Posted by Js116i View Post
Hi all!
Fault codes were
140010
140410
140001
Thank you
can I ask the exact spark plugs model number?
      09-06-2023, 11:04 PM   #5
Wellingtonz
what is pcv exactly?
      10-02-2023, 12:48 PM   #6
Andyc380
Drives: BMW F20 116i Urban
Hello mate . Same fault codes with mine.. did you ever get to the bottom of this?
Would really help me out with your findings
      12-11-2023, 02:40 AM   #7
Tjololo
Drives: BMW F20 114i urban line
Hi...check your ECU unit.
Sometimes a faulty ECU unit causes a misfire in one or two cylinders. I faced the same problem, sent the ECU to be repaired and re-programmed and the problem was solved.
