10-02-2019, 02:33 AM | #1 |
Rep 2
Digital cluster retrofit F20
Good morning all,
Maybe already a post was created but I did not find. I have a M140i Xdrive F20 ZF8 (european version) 01/2017, I'm looking for the right reference to do a LCI cluster retrofit (same as LCI 2018/2019). I know it will have to be coded for it to work. Can you help me ? Sorry I do not speak English perfectly. |
10-04-2019, 04:19 AM | #4 |
Rep 2
10-04-2019, 11:09 AM | #5 |
I /// M FAN
424
Rep 427
I think you don't get it, you use realoem to get the part number you want to install, then you can check if it's compatible with the existing part and install it or not. Retrofit can be done with oem parts or third party manufacturers. If the cluster your are looking for has the same size and connections as the existing one, then you can install it, after that you will need to code in order to make it compatible
Tags |
f20 cluster retrofit |
