04-13-2019, 02:04 AM | #1 |
Guest
Rep n/a
Drives:
M140i Finale Edition
Hi all 1 series fans and drivers
I am not sure if some of you feels the same, soon the 1 series approaching the end of straight six rear drive, I am thinking of getting another one Went to BMW Adelaide dealer this morning, spec up a M140i Finale Edition with the following options 1. Tyre pressure monitor [B39] 2. Sun protection glazing [2VB] 3. Through loading system [420] 4. Lumbar support, electric [488] 5. Seat heating for driver and front passenger [494] The price was AUD65500 (approx. GBP 35930; EUR 41470) with the possibility of further discount. Not driven a M140i before, but currently owned a 2016 LCI M135i, with similar option as above. I notice there are some items not available in the M140i... >rear seat storage net behind the front seat >rear doors storage compartment >12V power point behind below the rear vent >boot space 12V power point >boot cargo net >cargo net hook points behind rear seats and near B pillar Not sure what else are taken away, but these are all I can find out, and I think these little thing makes the M135i a more complete car. So let go back to the pricing, I am thinking of offering AUD 58000. What do you think of the price, is it a good deal? Or I should keep the money and wait for the new 1 series or keep saving for a M2 Thanks. |
04-13-2019, 02:24 AM | #2 |
Rep 3,290
One more thing that is not available at the current M140i, is a manual gearbox, unfortunately. The world's last six cylinder RWD hatchback with a clutch pedal has already been sold.
04-13-2019, 03:31 AM | #3 |
Guest
Rep n/a
Drives:
Yes, manual is definitely nice, I did regret not getting manual for the m135i initially, but after driving the auto, I think the the auto gearbox can shift better/faster and rev match more accurate than me One day they might have an auto box with voice command for change gear instead of paddle shift
04-13-2019, 06:59 AM | #4 | |
Rep 1,341
Don't wait for the new 1 series if you would be after M2. If you consider a (only available currently) used M2 saving should be a good idea apparently. If you are after a new one which will be M2C effectively, consider pricing increase over the regular M2 to evaluate your perspectives reasonably. |
04-13-2019, 08:59 AM | #5 | |
Rep 3,290
The auto is still faster, but not as rewarding to drive. |
04-14-2019, 03:58 AM | #7 |
Guest
Rep n/a
Drives:
Sounds good with storage package included Thank you for the information.
Yes, auto definitely not as rewarding as manual, my daily Fiesta is a manual and very fun to drive, not fast but on those twisty mountain road it is great, easy to get on limit without pushing too fast. Didn't have any plans to upgrade or mod the M135i, as modding cost is expensive in Australia, choices of mods also limited, the only thing I want to put in the car is the M perfomance Christmas light steering wheel Modding likely reduce the reliability, I don't plan to sell the M135i... so M2C is about 1.5 year saving away. |
04-27-2019, 02:53 PM | #8 | ||
Rep 16
2018 M140i M-perf LSD Akrapovic dp catback
1998 E36 323i track build full class-2 1995 LHD eurospec Mazda Rx-7 FEED widebodykit RB ducktail EFR7670 single turbo |
04-27-2019, 04:29 PM | #9 | |
Rep 3,290
I would have preferred automatic rev matching to first gear as well, as it is the most difficult gear to do manually. |
04-27-2019, 05:15 PM | #10 | ||
Rep 16
PS never shift back to first gear while driving thats just really bad for your manual gearbox!
04-28-2019, 12:46 AM | #11 |
Rep 3,290
Could you please explain what your car is doing when it is rev matching while shifting up? I don't understand why it should not be rev matching.
Please also explain what harm shifting to first gear while driving does. It is a very common thing to do when participating in auto-X, which is a sport I have been enjoying for many years. |
04-28-2019, 04:27 AM | #12 |
Rep 58
Imhk, first gear handles a very high amount of torque inside the gearbox due to high ratio. Its fair when engaging clutch as the friction losses lower the high burden.
After that its not advisable to floor because it strains too much the internal from both sides, engine and tyre torque is amplyfied to extreme values. Of course a good driver can use 1 gear with a gentle use of throttle and proper shifting rev matching. But It is nevertheless not advisable to use it often while driving. That's why first gear is many times wobbly and damaged in old cars with common improper driving. |
04-28-2019, 05:48 AM | #13 |
Rep 3,290
The gearbox is connecting the engine and the differential. It will see torque from both sides.
The maximum torque from the engine side depends on the engine performance, but the driver can momentarily get it even higher by dropping the clutch at high RPM, due to rotational inertia in the engine. None of these torques are higher in first gear than other gears. A clutch drop in the highest gear is worst case. It is sometimes done to test for clutch slippage. On the output side of the gearbox, the torque is higher the the input side, particularly in first gear. It is however limited by traction. If the torque gets too high, it will simply wash away in wheelspin. Unless you have tyres with grip that is significantly better than normal, the gearbox should be designed to handle this torque. There is also synchromesh to match the speed of the input shaft with the gears. If you shift too fast, these can wear out. You will hear crunching sounds when engaging the gear with worn synchromesh, unless you double declutch to sync in manually. I sometimes do that for fun, as it feels great to feel the gear lever go into gear with no resistance. The procedure is basically to shift to neutral, clutch out, rev match, clutch in, then shift to the gear you want, if necessary rev match again, then clutch out. On old trucks with unsynchronized transmissions, you actually have to do this. |
04-28-2019, 09:13 AM | #14 | |
Rep 1,341
Amazingly, I had to use double declutching on my current car to shift into the reverse (unsynchronized!) gear when brand new. When stationary (for just a bit too long, I guess ), of course. When picking the car at the dealer's I had to address the salesman to reverse the car into a parking spot (I wanted to drop in briefly again). He did, but failed to teach me how. It took me a few more gettings stuck to park to realize/recall the double declutch method (which went unnecessary really soon though). |
04-30-2019, 01:18 AM | #15 |
Rep 547
I wonder what the final price will be for the M140i. All current offers end the 30th of June which I believe is the last chance to factory order. The cheapest offer I have seen is for £333 deposit and £333/month.
Although the next M240i will still have a 6 cylinder, have the new bump stop suspension and an LSD, it won’t be as cheap. Even a 220i cost as much on finance as an M140i. A 440i is roughly £170 more per month and is more of a GT Towards the end of June I will stay in touch with My local dealer and TRL as I will be happy to pull the trigger if the price falls to £300 down and £300/month.
Previous Bimmers: F25 X3 20d LCI xLine, F30 320d Luxury
04-30-2019, 03:11 AM | #16 | |
Rep 300
04-30-2019, 04:31 AM | #17 | |
Rep 547
I’m open minded about factory ordering or buying inventory. Thankfully all inventory are shadow edition and automatic so the only clincher is finding one with Adaptive M Suspension which is surprisingly not difficult. The only colour I don’t want is grey. My GF won’t be pleased if I decided to go ahead in the next 6 weeks. However you only live once and I don’t fancy spending £520/month on the up and coming M240i next year. At that monthly payment I might as well buy an M2 or M4 both of which I’m not at liberty to spend money on right now.
04-30-2019, 07:40 AM | #18 |
Rep 1,341
Really?
You remind me of a Benny Hill Show episode. I can't find a video, but it went like that. Two doors (in an eatery?): "Cheap" and "Cheaper". Your choice is obvious. The same thing ("still cheaper"), the same choice. Again. Taking the last "Cheaper" ("the cheapest") you find yourself in the street. Your GrandFather, you mean (the one who always knows better)? |
04-30-2019, 10:38 AM | #19 | |
Rep 547
As for my GF(Great friend and Girlfriend) I bought her an iPhone XR earlier this month and we’ve ordered an well optioned G01 for her to potter around in so she’s not in a position to object to an upgrade for myself. Either way I’m taking time off work next month to play the field by trying the Golf R, RS4, M140i, M4 and C63. On the other hand there is no point as the finance offers for the M140i are unbeatable. *Geez, I should stop trying to talk myself out of buying the car*
05-03-2019, 02:51 PM | #20 |
Rep 547
Update! I've placed an order. £333 deposit and £343/month for:
M140i Shadow Edition Edition Alpine White Cognac leather Gloss black trim Automatic Adaptive M Suspension Front Parking Sensors Heated seats It's a deal of the century and one that I would have regretted not exploiting. You only live once and in two months there won't be a 6 cylinder 3L hatchback avilable to order new. My GF won't appreciate the sound of a throaty engine firing up on the drive way every morning!
05-04-2019, 01:50 PM | #22 | |
Rep 547
It's a shame that the Finale Edition won't be offered at the UK because the all the additional features e.g. Adaptive Dampers, Front Parking Sensors, Wireless Charging, Sun Roof and Comfort Access, Professional Media, Metallic Paint and Extended storage add less than 1/3 of their real cost to the price over a regular M140i. Either way the Shadow Edition still add a few goodies like Cruise Control and HK Sound.
