BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > BMW F30 316 I 04/2013 engine N13 , Turbo get too red and hot
      03-03-2014, 08:18 AM   #1
Adel-75
Tunisia
Drives: BMW E92 LCI,320D , 04/2010
Dear Mates ,
I already post this Thread under 3 series but a mate have suggest to me to put it here as there is more chance to be answerd and to solve the issue .
Also he told me that there is someone called :
ovekvam he has a 116i M-Sport which he races on track with now and then.
so please if he can see this he can help , Thanks
http://www.f30post.com/forums/showth...1#post15531813
please can someone help me with this issue , I am surprised and scared I have my car BMW F30 316 I 04/2013 engine N13
when I look on my engine I found that the car turbo is getting too red and hot which scare me a lot .
I ve took the car to the BMW dealer : they change Turbo , Intercooler , Lambda sonde and nothing changes it still the same issue !
please advise what should I do ?
with kind regards
Adel
      03-03-2014, 05:00 PM   #2
pron
Drives: 125i M sport
Steel begin to glow red at around 600 celsius, and exhaust gas can reach mutch higher temp. Here you can read an article about temperatures in and around turbos.
http://www.epi-eng.com/piston_engine...technology.htm
      03-04-2014, 12:27 AM   #3
I have discussed the issue with Adel-75 in private messages, and I have nothing to contribute here. It is my first turbo car, and I have never checked under the hood shortly after driving hard.
      03-05-2014, 04:44 AM   #4
dape90
Drives: 2013 F20 118i M-Sport
Turbos get hot.
Back in the day I used to own a Subaru STI 5 Type RA (terrible car which I wish I had never bought). When I drove it hard the turbo would glow red.
While I have not lifted the bonnet on my 118i after a hard drive I am sure the turbo will be glowing. And you really don't need to worry.
If you start hearing a whining noise then start to worry as the bearing are shot in the turbo. But modern BMW engines look after there turbos. Back in the day you would need to leave a turbo engine to idle for a bit before turning it off. This would allow the oil and water to circulate around the turbo and cool it.
On modern engines this idle period is not quite so important as the ECU can run the oil and water pumps after the engine is turned off if the turbo heat is high. I do the idle thing though, old habits and all that.
Alternatively, don't rag the car so hard. Put it in ECO mode, and use the change indicator. That way the turbo never produced boost and won't get as hot.
It will also be the most boring drive ever.
I hope that helps.
D
      03-05-2014, 12:20 PM   #5
Adel-75
Tunisia
Originally Posted by dape90 View Post
Turbos get hot.
I hope that helps.
D
Thank u for ur help .
please just if possible and a day u can take photo after a hard drive just shared but I do fully agree u and trust u
do u think that there is an additional way how to cool more my turbo ?
regards
Adel
      03-05-2014, 01:39 PM   #6
vladberca
vladberca's Avatar
Romania
769
I don't think the car needs an additional cooling system if you keep the standard power.
Only MPPKs have larger cooling systems.
      03-05-2014, 02:38 PM   #7
Phantom3D
Drives: F21 120d a m-sport
I have driven loads of japanese turbo cars (Supra, Skyline's, STI, evo ++), after hard driving they are all orange-ish and very hot. You can easly light a cigarette on them.
Those japanese cars have been pushing from 0.6 BAR to over 2 BAR.
That beeing said, I think your turbo looks very red, that might just be the picture. Not sure.
      03-06-2014, 12:49 AM   #8
Adel-75
Tunisia
Thank u Mate ,
no it red glowing and not orange , it become orange when it is going to cool at ideling .
regards
Adell
      03-06-2014, 05:30 AM   #9
Phantom3D
Orange at idleing sounds very wrong..
The fault is propably that your turbo is spooling fast on idle. A bootsgauge would be great here :-P
This can be caused by alot of things:
actuator (I think?), air-intake sensor (Wrong air temp sent to ecu, much richer fuelmix) and timing are some of them.
I would try to get a new turbo aswell as it getting this hot is not good.
I am sorry but my knowledge of this stops here.
      03-07-2014, 01:36 AM   #10
Adel-75
Tunisia
Hello Mate ,
I have gone to the dealer as the car was only less 15.000 KM and 04/2013
so it is under guarentee .
they done diag online from Germany
result : the dealer have alredy change to me : nwer Ctalyser with Lamda , sonde , new Turbo , new intercooler
nothing have changes , it still the same situation Turbo get too red and hot when I activate boost and drive on high rpm
by the way I have ICOM myself , ECU have zero error , no error on diagnostic , so if it was Mass air flow or timming or actuator , it will apear on diag !
with kind regards
Adel
      03-07-2014, 02:25 AM   #11
What do you mean when you say "activate boost"?
      03-07-2014, 03:12 AM   #12
Adel-75
Tunisia
sport mode button , ECO pro ! I think when u activate this button even the turbo management way changes also !
with kind regards
Adel
      03-07-2014, 03:28 AM   #13
with kind regards
Adel
Eco Pro is a setting for the car to save fuel. It changes the the throttle pedal mapping. If it affects the turbo boost, I assume it will be lower than in Comfort/Sport.
      03-07-2014, 06:04 AM   #14
RIOBLAST
RIOBLAST's Avatar
Sweden
34
Drives: 330xi G21 ELSD
Since ecopro makes the Auto change gear much sooner it doesn't use the turbo as much. When accelerating it shifts up before 1800rpm.
      08-02-2023, 05:45 PM   #15
Caner55
Drives: Bmw 1 series F20
Dear Mates ,
with kind regards
Adel
Please help me i have exactly the same problem how do you have solved it ?
      08-04-2023, 07:47 PM   #16
No one
Drives: F21 118i
The solution is not to look. I don't. Nor worry. Say, ovekvam had the whole car orange, but he didn't seem to worry either.
      08-09-2023, 04:37 PM   #17
Caner55
How is the problem solved? I have the same problem
      08-11-2023, 08:35 AM   #18
DomMuc
DomMuc's Avatar
531
Drives: G87 M2
there is no Problem.. this is normal ....
