BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F30 320i vs F20 118i
      02-25-2013, 10:46 AM   #23
rpagianotto
Drives: F22 m235i 8AT
Originally Posted by Jameson View Post
Just when I have clear that I want the 118i, I read this and all change... I worry when you said it just sounds like a diesel engine !!! I want a petrol because I like an engine wich doesn´t sound like a truck,,, If botf (118i, 118d) sounds the same, then I would go for the diesel because the compsumption... wouu
Hmm, in my opinion, they sound similar only when idling. Once you get rolling with them the petrol sounds much better. And also, you get almost 2000 extra rpm's with the petrol, and the sound on the top end really sets them apart.
Of course, none of them sound anything like an i6...
      02-26-2013, 10:04 AM   #24
Jameson
Drives: 116i
Thanks a lot, I have one question for you... What is your comsumption usually??
Take a look at what I have readen in an article about a 118i test drive:
"With a petrol engine as good as the 118i, the case for the diesel is significantly diminished. Power is up, the torque gap has narrowed, and the fuel consumption advantage of the diesel hauled back"
      02-26-2013, 10:53 AM   #25
rpagianotto
Hmm, around town i get 10-11l/100km, and on the motorways around 7l/100km. But bear in mind that I'm in Brazil, and here our petrol has 25% ethanol in it, therefore the fuel consumption is significantly worse.
      02-26-2013, 11:15 AM   #26
125
Drives: F20 LCI 118i M-Sport B38
Do you have a special version of the engine since you can run E25? Our car states that it can run E10 maximum.
      02-26-2013, 11:25 AM   #27
logiclee
Drives: BMW 116i
Agree, at idle they both have high pressure direct injection noise but after that they are worlds apart.
Cheers
Lee
      02-26-2013, 04:05 PM   #28
Brenyaman
Brenyaman's Avatar
Spain
Drives: F20 120D Aut Urban
Si has leído bien mi mensaje, digo que tras unos momentos (10, 15 segundos) el rumor diesel desaparece y suena gasolina 100%... Como dice otro forero, sólo ocurre en frío al arrancar, y el sonido no tarda nada en cambiar...
      02-26-2013, 04:06 PM   #29
Brenyaman
Brenyaman's Avatar
Spain
Cheers
Lee
Which is exactly my point. The diesel noise vanishes in a few seconds...
      02-27-2013, 02:47 AM   #30
Jameson
Drives: 116i
Muchas gracias por la información. ¿nos podrías comentar datos sobre tu consumo? sigo con la duda entre el 118i y el 118d, hago unos 25000 Km al año. La opción lógica es el d, pero me apetece olvidarme de ruidos, vibraciones, etc. de los diesel... gran dilema.
Thanks a lot. Could you tell us about your consumption? I have a doubt between 118i and 118d, I make about 25000 km a year, so diesel option is more logical, but in the other hand I want to forget noises and vibrations of diesel,, a difficult quiz!
      02-27-2013, 04:42 PM   #31
rpagianotto
I'm not actually sure there are any modifications to the engines destined to Brazil, but the service intervals here are significantly shorter - my car asked to have its oil changed at only 4000km!
      02-28-2013, 06:48 AM   #32
Brenyaman
Brenyaman's Avatar
Spain
7 l/100 after 11.000 kms. 80% in motorways & A roads (legal speed), 20% city traffic. Making 25.000 kms/year I wouldn't go for diesel. That's the limit, above that, I'd think about it seriously.
