BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > A/C auto question
      08-27-2012, 12:03 PM   #1
166
Drives: F20 LCI 118i M-Sport B38
A/C auto question
In the 116i, I have closed the center vents and the side vents, since I don't like to get cold air blown in my face while driving. If I set the A/C in auto mode, it hardly has any cooling effect at all. I set the wanted temperature to 16 degrees, and outside it is 18 and sunny. The car has factory tinted windows, but there is no way the A/C can keep the temperature down. It get really warm inside. Probably well over 30.
Is the A/C system completely unable to blow cold air up or down in auto mode?
If I set the system to manual settings, select up and down, and set a manual intensity, it gets cold inside.
Is there something wrong with the car, or the user?
      08-27-2012, 02:05 PM   #2
logiclee
Drives: BMW 116i
In Auto if the system detects it needs to cool the interior rapidly it will direct the airflow towards the vents.
As you have closed the vents manually you will not get any airflow.
If you close the vents then you will need to manually select the air direction settings.
Cheers
Lee
      08-27-2012, 02:55 PM   #3
166
So if I want air flow up and down, I can not use the automatic setting to control the intensity?
      08-28-2012, 02:13 AM   #4
logiclee
Drives: BMW 116i
If you are in Auto, then alter the air direction to up and down then the climate control should control the fan speed to achieve your desired temperature.
Cheers
Lee
      08-28-2012, 03:04 AM   #5
fuzzer
Drives: 2016 X3 20d SE
have you got the AC turned down in the eco pro settings?
      08-28-2012, 04:21 AM   #6
166
If I change the air direction to up and down, the auto function goes off. If I switch it back on, the air direction setting is removed.
I am not using Eco Pro. I drive 99 percent in Comfort mode in public traffic.
      08-28-2012, 04:48 AM   #7
wolz
wolz's Avatar
Sweden
Drives: bmw F20 120d
When hot and sunny I quite often set the direction, temp and speed manually aswell as I'm not happy with the auto-setting which indeed use the center/side-vents way too much instead of using foot and windscreen vents...
driving for hours on a hot sunny day in automode usually give me a headache and an aching neck.
      08-28-2012, 05:05 AM   #8
rickk
rickk's Avatar
Netherlands
Drives: E30 325i, E46 320d, F21 125i
Maybe only opening the rear vents is a "solution"?
2013 F21 125i Estoril Blue M Sport
2002 E46 320d Steel Gray M Sport
1986 E30 325i Royal Metallic Blue
      08-28-2012, 05:08 AM   #9
166
You mean the ones for the back seat? I will try that if the summer comes back! :-)
      08-28-2012, 10:28 AM   #10
logiclee
Drives: BMW 116i
Even though the auto light goes out (Because you have set something manually) the Climate should still control temperature and fan speed.
Cheers
Lee
      08-28-2012, 12:07 PM   #11
166
Cheers
Lee
Seems like it still tries to keep the temperature, but the fan speed goes manual when the auto light is off.
      09-04-2012, 11:14 AM   #12
166
One more question: There seems to be four temperature dials. One digital setting for each zone, one analog thumbwheel for the center vents, and one analog thumbwheel for the back seat. Is there some sort of mono setting to control everything from one dial, instead of always having to adjust all four?
      09-04-2012, 12:41 PM   #13
Ozolz
Drives: 116i m-sport 2014
I dont understand how you can expect to have auto setting when u block the most used vents....
      09-04-2012, 03:07 PM   #14
rickk
rickk's Avatar
Netherlands
Not that I know. In previous cars there was at least an option to sync the two zones, but for some silly reason they removed it from the current generation of cars.
I'm pretty sure the other two controls are fully mechanical (at least in previous models they were), so it'll be hard to sync them with anything. EDIT: it seems they've been digital for quite a few years.
Although I think there are too many temp controls, I must admit I kind of like that (typical BMW) feature, especially in winter, as it allows you to set the face level vents to be a little cooler than the rest of the car.
Or, do as my wife tends to do in the E46 when she drives to work in the morning: set them to ultra-toasty and use the vents as a hair dryer! (not kidding!)
Note that in the middle position it should blow the same temperature as the other vents.
      09-05-2012, 01:50 PM   #15
bimmer man
52
Drives: 640i Convertible, 420d xdrive
2016 Bmw 730d xdrive  [5.00]
2012 640i  [5.00]
Ovekvam Hello, my wife has a 116d and there have been problems with clima for a long time. To begin with ac power badly and later joined the star on the ac button flashing and ten finally shone ac button only occasionally. Went to Bavaria and did confirm that electrical block for air conditioning need to be replaced, waiting on parts now. Bavaria could tell that this was more F 20 is that had this problem.
      09-20-2013, 09:27 AM   #16
matsemann
Drives: F20 116ds Sport
Can anybody confirm how the fan behaves in you car when using AUTO on the Automatic aircon? From my old E87, I remember that AUTO would adjust the fan speed, but on my F20, the car can be 30 degrees inside, with the temp set to 18, and the fan speed will not adjust automatically. I have to select the desired fan speed manually.
Mats
      09-20-2013, 03:25 PM   #17
166
In our 116i, the fan speed is automatic in auto mode. You can still change what looks like the fan speed, but it is in reality the intensity of the climate control. On cold days, the fan speed will be low until the engines starts getting warm, and then it will speed up the fan to heat the interior.
      09-23-2013, 02:27 AM   #18
Fanis
Fanis's Avatar
Greece
34
Drives: 116i (F20) Auto
Mine works as ovekam described. I have the Climate control set at 22oC with outside temp of aroun 30-33oC. The fan initially runs faster and then it slows down. If I lower the desired temp. for example to 18oC, then the fan starts running fast again. So definetely the fan speed adjusts automatically.
2011- : BMW 116i (F20)
2009-11: BMW Z4 2.5si (E85)
2007-09: Mini Cooper S (R56)
2005-07: BMW 325ti (E46)
2004-05: BMW 318i (E36)
      09-23-2013, 03:52 AM   #19
matsemann
Thanks, I will have another look. Guess Im just used to seeing the "fan speed" thingy increase when the fan speeds up
      09-23-2013, 04:32 AM   #20
orcomma
Dividing by zero
orcomma's Avatar
Drives: F48 X1 XDrive20d xLine
I'm sure it used to go up and down in my dad's E36
Maybe they changed the fan display for the new BMWs?
The Night Project - X1 20D xDrive xLine - Black Sapphire, Sun Protection Glass, 19" 511 wheels powder coated in high gloss black, Shadowline trim, MPerformance grilles.
      09-23-2013, 04:42 AM   #21
166
When the A/C is set to manual control, it displays the fan speed. When it is set to auto mode, the display indicates the intensity. The intensity is manually controlled in auto mode. When set to high intensity, the fan speeds are generally higher than when set to low intensity.
      09-23-2013, 05:14 AM   #22
Bob UK
Drives: 2013 X1 18d X-Drive
That makes sense, I was wondering about the fan speed and the fact the indicator was not changing as it used to in my e46. The fact the cars have dual zone and only one indicator probably has something to do with them seemingly operating more stealthily.
