BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > 116d or 116d ED
      08-15-2012, 04:33 PM   #1
ghostbmw
Drives: BMW
116d or 116d ED
Hi guys,
After a couple of months reading you all (let me say that this is by far the most active forum for 1 Series I have seen in the web), I made the decission to join myself this forum. It was not easy as I had several problems with the register process (it seems that my IP was in a kind of blacklist or something like that), but finally I was able to complete the registration process, so here I am.
First of all, let me introduce myself, my name is Jose and I'm from Spain (since now my apologies from my english grammar mistakes...) and I will be the future owner of a BMW 1 Series 116d or 116d ED, still not sure.
Well, I'm about to order a new F20 in next days and I'm still have doubts between normal 116d an ED version. I know there have been some discussions about this, but I would like to ask you again because in Spain, both cars have exactly the same price, and also they have same taxes, etc... this is, money is not a factor to make the decission as both costs the same and we don't have (at least at this moment) city taxes for pollution or taxes like that.
My first decission, was to go for the ED version, as I saw that both (normal and ED), had the same power, same torquee, and ED was only 0.2 sec. slower in 0-100 acceleration (10.3 for the normal version and 10.5 for the ED one). But further research I saw that ED version seems to be significantly slower on the 80-120 kmh acceleration in 4th and 5th gear: 8.6 and 11.7 for the normal version, while the ED needs 10.2 and 14.2. So after discovering that, I changed my decission to the normal 116d. Anyway, after reading your comments one time and another, it seems that 116d ED owners are quite happy with the car... so, I have a serious doubt about the version to choose.
Taking that into account, and remember that money is not a factor in Spain which car you will go? Will you go for the 'extra' power of the normal 116d or will you go fot the ED version to take advantage of its reduced fuel consumption? My dealership advised me to order the normal 116d...
Any feedback, comments will be welcomed.
Thanks in advance guys!
      08-15-2012, 04:44 PM   #2
fuzzer
Drives: 2016 X3 20d SE
I would order the normal 116d
If money isn't an option how about a 116i ?
      08-15-2012, 05:36 PM   #3
orcomma
Dividing by zero
orcomma's Avatar
Drives: F48 X1 XDrive20d xLine
the 116d uses a 2.0 litre N47 diesel engine
the 116dED uses the 1.6 litre diesel engine from the Mini
that's why there is slower in gear acceleration
I have a 116d Non-ED and I managed to achieve 64.4mpg UK (4.4 L/100km) driving at about 70mph on the motorway.
I find cruise control significantly reduces consumption on the motorway too, so I try and use that as often as possible.
      08-15-2012, 06:55 PM   #4
ghostbmw
Drives: BMW
Hi,
116i is actually same price in Spain than 116d and 116d ED, but I plan to do 25.000 km per year, so I discard the petrol option due to the running costs...
Thx
      08-16-2012, 01:40 AM   #5
Superspeed
Superspeed's Avatar
33
Drives: 640i, 120d, Cooper S
Welcome to the forum!
I haven't tested any of the two cars, so my point of view is entirely based on tech specs.
I am sure both are good engines, but to me the difference in consumption isn't big enough to justify the ED as long as there are more important qualities in the D.
Intermediate acceleration is an everyday quality that you enjoy each and every minute you are behind the weel. Not the (almost identical) consumption figures!
I know ED owners are happy with the car, and from the specs it is a good and competitive car.
But to me it would be a matter of driving pleasure. So I'd picked the 116D
[SIGPIC]"Never a boring car"
Some X'es: BMW Z3 2.8, DeTomaso Pantera, Porsche 928s, BMW 732i, BMW 323i, BMW 2002
      08-16-2012, 02:17 AM   #6
125
Drives: F20 LCI 118i M-Sport B38
I also haven't driven there two cars, but in general smaller engines are better at running at low loads, like urban driving. If you do a lot of high speed highway driving, the bigger engine could match the consumption of a smaller one, since it can pull longer gears.
An extreme example of this was shown on TopGear, where a BMW M3 had lower fuel consumption than a Toyota Prius when following it around the TopGear test track (Prius driven flatout).
      08-16-2012, 05:52 PM   #7
ghostbmw
Drives: BMW
I tested the normal 116d, it was not a rocket, but I liked it, I think it will be enough, but I think also that less performance would make the car a bit slow... and that's why I was trying to ask some impressions about the ED..
      08-16-2012, 06:27 PM   #8
KoenG
Belgium
43
Drives: E39 530i & F10 LCI 518d
Torque seems to be the same at 260Nm over the same band, but probably the end reduction of the transmission is longer on ED. The 80-100km/h show a difference of about 20%. No doubt I'd go for the 116D which will feel an entire unit stronger. The few deciliters/100km are even smaller in real driving conditions, maybe entirely wiped out even.
Have you considered the 118d? Same engine but less restricted, providing a sensible amount of extra push. Since I understand that the 116D was not really satisfying you either (so forget about the ED all togheter)?
      08-16-2012, 06:41 PM   #9
ghostbmw
Drives: BMW
Hi Koeng,
Torquee is the same in both versions, as also end reduction is exactly the same (I checked that in the BMW's web page and catalogues), and that's why I don't understand very well that difference in 80-120km/h as they have same power, same torquee, same transmission... so it's seems too much difference considering they have similar specificiatios and the only difference in 0.4 litres less in the ED.
Regarding the 118d, the answer is Yes, I considered it, it's around 1.500 eur over the 116d. I discarded the 118d because the car is going to be our second car, driven mainly by my wife (who maybe will have enough with the ED version, but I want to drive sometimes the car). If it were the first car, I will go for the 118d.
      08-16-2012, 07:52 PM   #10
KoenG
Belgium
43
I also checked, since I'am a bit taken here, I admit, the engine has identical torque in the identical rpm band and the weight is identical also! The gear box is the same, and.... the end transmission on the ED is even SHORTER not longer!
In the (belgian) specification, the end ratio is 3.08 to 2.93 for respectively the 2.0l and 1.6l. Meaning that the 1.6d is pulling shorter with the same engine output power! The 80-100 is repectively 8,6/11,7s for 2.0D versus 10,2/14,2s for 1.6D.
Well frankly, I cannot explain! The only explanation left is the 1.6d drops off very fast, but it also delivers identical kW at identical rpm than the 2.0D so it steams up identical to 4000rpm! Under these circumstances, who can explain the figure of the borchure?
I cannot! Bur i'am also anxious to understand.
      08-16-2012, 08:08 PM   #11
KoenG
Belgium
43
Hey, I just see on the next page that the ED has tires 205 and the 2.0d has 195 at identical 55/16, meaning that the ed has a longer convolutive: one turn of the wheel brings you 198,5 cms further, the 2.0d only 195 cm. This implies the 2.0d gains on strenght here, but only very mariginal. Not explaining the 20% anyway!
      08-18-2012, 08:31 PM   #12
alex004600
Drives: BMW 325TDS
I would go for the ED in case of city driving, due to the low consumption. If you plan to drive mainly on highways go for a 2.0L engine, i think the plus 1500 euros for the 118d will worth, even if you have to cut an extra, the car will be more fun to drive.
      08-19-2012, 06:38 AM   #13
orcomma
Dividing by zero
orcomma's Avatar
My partner has a Mini Countryman CooperD with the 1.6 N47 engine and he struggles to get more than 50mpg out of it, but that could be the aerodynamics.
      08-20-2012, 05:55 PM   #14
ghostbmw
Drives: BMW
Hi,
Regarding the Mini Countryman Cooper D with the 1.6 N47 engine there are some funny data that I still can't explain. The fuel consumption can be explained due to the aerodynamics, as the Cx is not very good, but there are some strange data regarding the performance:
0-100: 10,9 s. (10,5 s 116d ED)
80-120 (4 gear): 9,7 s. (10,2 s. 116d ED)
80 -120 (5 gear): 11,9 s. (14,2 s. 116 ED)
I still can't understand why using the same engine, the 116d ED is able to be faster than the Mini on the 0-100, but is significanly slower in the 80-120, specially in 5th gear as almost 2.5 secs seems to be too much...
With regard to the 118d, I agree that usually it worths to pay for the engine, but in my case, the car will be driven on highways at a moderated speed, so I think I don't need the 118d.
      08-23-2012, 09:21 PM   #15
alex004600
Drives: BMW 325TDS
..some differences for similar weights. Gear ratios and "ED" optimizations doing the timing differences.
I did a test drive on the ED and it seems Ok to cruise in highways. It as lowered suspension, an advantage to the normal 116d.
A downside is that only 16" wheels can be fitted in the ED model, the car looks better on 17".
i suggest a test drive on the ED to compare the engines
      08-23-2012, 11:52 PM   #16
AusF20/F48
AusF20/F48's Avatar
If it is your wife who will drive it mostly it does not matter to much with variant you go with as they have similar specs
You can chip tune them later if you want more power.
It is more the extras you need to consider now.
I am sure that you have read many threads about the 'must have' options.
At the end of the day whichever F20 you choose it will be a nice ride.
Good luck, the list of extras and options is where you need to use your head not your heart.
      09-02-2012, 08:44 AM   #17
troggy1969
Drives: 335D MSport 2016
Looking at the ed figures from the Autoexpress road test it looks like BMW may have published conservative figures for the ed.
http://www.autoexpress.co.uk/volvo/v...-v40-vs-rivals
0 - 60 (96): 9.9sec
50 (80) - 70 (112): 9.8 in 5th
      09-02-2012, 12:00 PM   #18
troggy1969
You got the ratio right but the result wrong. The 1.6D has less of a reduction (2.93 v 3.08) so it is higher geared
116d, 116ed
