| 05-28-2012, 11:11 AM | #1 |
Rep 27
Choppy steering when turning
Hey everyone,
Got a new 116i f20 a few weeks ago. Have servotronic.driven 1000 km. Really love the car, but after i've been driving on some bumpy roads this weekend the steering feels choppy at times in long turns above 60 km/h. Turning the car eg. to the left is okay, but while in the turn and when going back to neutral position in a long turn it feels choppy, almost as if i reach a point where i have to overcome a certain amount of power before i can continue to turn the steering wheel. Not much power needed to overcome this point, but i can feel it and cant remember feeling the same just a week ago. Anyone else noticed this? Does your car/steering feel smooth throughout a long turn? Maybe im just being too sensitive? |
| 05-28-2012, 12:19 PM | #2 |
Rep 28
interesting...
I exactly understand what you mean by that. I have my 118i for 5 months now, and every now and then (like 1-2 a month) I experience the same thing. When I try to turn the steering wheel it's like I have to overcome some bubbly counterforce. It's not sharp, actually it's just noticable. But I couldn't relate it to any situation. I asked the BMW service trying to identify the problem but they could not reproduce it and also couldn't relate it to anything. At least we can presume it's not a chronic serious problem. Please keep me posted if you come up with any news, I'll do the same. |
| 05-28-2012, 01:57 PM | #3 |
Rep 9
A few more have this problem in the Netherlands. Mine did get it after I recieved a software update (see problems topic).
I have notified BMW before my car was there for normal service. They told me BMW Netherlands adviced to change the whole steering (the whole thing not only the wheel, but don't know the word for it). They do need to order it so I am waiting for the call to replace it. |
| 05-28-2012, 02:53 PM | #4 |
Rep 859
Drives: 640i, 120d, Cooper S
This has been an issue on a large German F20 forum http://www.1erforum.de/der-neue-1er-...ung-96115.html
Apearently, to save fuel the electronic servo cuts off when not needed, like when the steering wheel is held in the same position for a while (straight ahead or a long constant curve). When servo aid is needed you have to overcome an initial resistance. The problem is supposed to be known to BMW. When ordering my F20 luckily I had already read about this occasional problem, so I ordered the car with standard steering. Which turns out to be a real good one. No artificial feeling and very good communication between road and steering wheel.
"Never a boring car" ![]() Some X'es: BMW Z3 2.8, DeTomaso Pantera, Porsche 928s, BMW 732i, BMW 323i, BMW 2002 Last edited by Superspeed; 05-28-2012 at 03:10 PM.. |
| 05-28-2012, 04:35 PM | #6 |
Rep 9
Nope they didn't, but will ask when I will bring my car.
@Superspeed, both have the same problem standard and servotronic. So or you have been lucky, or they have fixed it with the newer builds? Mine is (116i) from October 2011. |
| 05-28-2012, 05:06 PM | #7 |
Rep 27
Well mine is built early April 2012 so it hasnt been fixed if im experiencing the same problem. Will call my dealer tomorrow and see what they say...
Sucks when these things happen to new cars :-( |
| 05-28-2012, 06:28 PM | #8 |
![]() 22
Rep 145
My advice before considering changing the column,ask the dealer to:
- reflash the ECU if it is a flash type - recalibrate the torque sensor Of course your dealer will tend to push for a change of the column, because they can make big money as it leads to many working hours (assembly and disassembly of steering column can take long due to difficult access and potentially instrument panel components disassy, if it is the rack it is even worse because then suspension alignment may have to be reset) it will be huge cost to be covered by BMW, your car will be blocked for longer and it is not sure it will solve the problem. NB: the steering wheel itself has nothing to do with this problem. Does anyone one know if the motor is rack mounted or column mounted? |
| 05-29-2012, 02:20 AM | #10 | |
Rep 859
"Never a boring car" ![]() Some X'es: BMW Z3 2.8, DeTomaso Pantera, Porsche 928s, BMW 732i, BMW 323i, BMW 2002 Last edited by Superspeed; 05-29-2012 at 05:30 AM.. |
| 05-30-2012, 07:15 AM | #11 |
Rep 27
Talked to the dealer today. Bringing in my car next week for a testdrive with one of the technicians. He was unfamiliar with the problem...
Will let you know what they find out... |
| 05-30-2012, 03:45 PM | #12 | |
![]() 22
Rep 145
![]() By the way, did you check tyre pressure? Generally EPS can be quite sensitive to left/right pressure difference (front tyres) |
| 07-19-2013, 05:32 AM | #14 |
Rep 4
Hi you all!
I'm in Spain and I have exactly the same problem with the steering. When engineers tested the car they did not found anything, so I will tell them what has been discussed in this forum to see if they get any ideas. The truth is that i'm very worried with this issue, as it is a very awkward behavior and I see no easy solution. ![]() |
| 07-19-2013, 06:21 AM | #15 |
'Captain Slow'
Rep 164
Drives: F20 118d M Sport
I've got the same issue, plus my steering doesn't feel particularly "safe" and I also have a knock from the front right area when going over bumps.
Dealer refuses to believe that there is a problem.... Joy! ![]() |
| 07-19-2013, 12:26 PM | #16 |
Rep 353
Note that the tyre pressure sensors only alarm if there is a sudden drop in pressure. If there is gradual pressure loss through a slow leak or faulty valve then you won't know about it. Worth getting a decent pressure gauge and checking them once a month to be on the safe side.
No Xenons but plenty of creature comforts. |
| 07-19-2013, 12:39 PM | #17 | |
Rep 3,290
| 07-19-2013, 08:43 PM | #18 | |
Rep 353
Always seemed wrong to me if it didn't as you could end up with a flat condition without knowing and be driving normally, meaning above 50mph, dangerous.
| 07-20-2013, 10:54 AM | #19 | |
![]() ![]() ![]() 6590
Rep 15,857
We could therefore note a difference, particularly to steering feel, before we ever get any warning of low pressures. Checking pressures regularly is the only way to ensure all tyres are at the correct pressure, with indirect TPWS. HighlandPete |
| 07-20-2013, 11:24 AM | #20 | |
Rep 3,290
I think most drivers wouldn't notice before the warning, but if you know how to check it, it is definitely possible to feel it. Easier on a track than on the road. |
| 07-20-2013, 11:38 AM | #21 | |
Rep 15,857
Many have been caught out in the UK, believing the trigger point will be well ahead of such a low pressure many find they have when a warning is given. Quite common for someone running around 35 psi to be below 25 psi when the warning goes off. So the sidewalls have been working hard for a good few miles in many cases. HighlandPete |
| 07-20-2013, 12:25 PM | #22 |
Rep 353
I miss pneumatic tyres, space for a full size spare wheel and jack, proper toolkit just seems we get less and less these days.....
| Bookmarks |
