| 05-28-2012, 04:14 AM | #1 |
![]() 8
Rep 93
HARTGE upgrades for F20
Last week I was checking with Hartge.de regarding the power upgrade, this is how they do it:
The Hartge Engine Conversion is significantly different to other, often cheaper systems. Our Hi-Tech system contains many "smart" technical features, and is the result of many months of design, testing and durability trials. The investment we have made during the development program has resulted in a full 3 year warranty on the hardware and software, plus an insurance backed engine and drive line warranty, covering any effect of the increased power output for a period of 12 months from installation date, but limited to 6,000 Euro. HARTGE engine upgrade is TÜV approved and legal in CZ. Technical features are as follows; The Hartge ECU is an external additional control unit. It is internally sealed and cannot be detected by BMW service procedure interrogations. It is also not possible that BMW software updates can disturb the performance of the Hartge ECU. Unlike engine management "chipping" and "flash" upgrades, it never gets overwritten during service enhancements by BMW. The Hartge ECU is connected via a special wiring harness to the standard fuel injectors, throttle pedal, exhaust gas temperature transducer and power supplies. There is no connection to the turbocharger, and we do not generate any influence on the turbocharger boost pressure, which could increase the risk of damage to the engine. Additional power is generated by increasing the fuel injector injection rate by a precisely calculated number of microseconds, this number depending on engine speed and throttle demand and other parameters. This additional fuelling makes use of the excess air delivered by the turbocharger, and consequently additional power is generated. The BMW ECU continues to monitor all other important engine parameters as standard. One of the safety features of the Hartge system is that it does not generate additional power until the throttle demand is increased to more than 70%. Therefore the engine behaves as standard until the driver demands the maximum power. This ensures that the standard emissions controls remain intact for the standard emissions tests and drive cycle testing. There is also overload protection, which prevents full power from being delivered for excessively long periods of time, for example when towing heavy loads, or driving for too long at V-max. The Hartge ECU also prevents overload of the transmission at lower than 1,500rpm, and overstressing the engine at high power outputs above 4,000 rpm. In extreme temperature conditions, the Hartge ECU also monitors the exhaust gas temperature, and if this exceeds the safe limit, the Hartge ECU reduces power accordingly back to standard BMW power. All standard BMW engine protection and emissions systems remain in place and continue to function. It's not cheap, but it seems to be pretty safe way of engine upgrade... |
| 05-28-2012, 09:04 AM | #2 |
Rep 485
Drives: 116i (F20) Auto
Is this for the Diesel engine only? Because for the gas engine, there is an increase in boost pressure (they interefere with the Turbo pressure valve)...I know because I installed it.
2011- : BMW 116i (F20)
2009-11: BMW Z4 2.5si (E85) 2007-09: Mini Cooper S (R56) 2005-07: BMW 325ti (E46) 2004-05: BMW 318i (E36) |
| 05-28-2012, 09:22 AM | #3 |
![]() 8
Rep 93
| 05-28-2012, 12:23 PM | #4 |
Rep 28
| 05-28-2012, 12:45 PM | #5 |
Rep 485
I have already posted a review and right now I am uploading some pics.
![]() http://f20.1addicts.com/forums/showt...=645440&page=3
| 05-30-2012, 05:10 PM | #6 |
![]() ![]() ![]() ![]() 197
Rep 908
Drives: F90 M5
I am drawn to this kit because it only works at over 70% throttle (so normal driving wouldn't stress the engine). However I just looked at the prices - £2,000 for the 120d kit
![]() Seems a lot for what looks like a tuning box (albeit one with some nice safeguards)...
F90 M5 (Marina Bay Blue, M Performance Parts) / U11 iX1 xDrive 30 (Storm Bay)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
| 05-31-2012, 02:15 AM | #7 | |
Rep 216
would much rather go for the bmw upgrade then which includes hardware and software upgrade (new bigger intercooler and a bigger fan). For the 120d it gives you 200hp and 390nm (184hp 350nm stock). Still same consumption/co2 emission according to bmw, and the comfort of knowing it's bmw-tuned with no worries what so ever about warranty if things go bad. Pricetag is about 1500Euro + work so probably end up around £2000 in total |
| 05-31-2012, 06:52 AM | #9 | |
Rep 859
Drives: 640i, 120d, Cooper S
I seriously consider taking my car down there to have it done.
"Never a boring car" ![]() Some X'es: BMW Z3 2.8, DeTomaso Pantera, Porsche 928s, BMW 732i, BMW 323i, BMW 2002 |
| 05-31-2012, 07:39 AM | #10 |
Rep 485
Thats quite expensive!! I do not know the price for the diesel tuning box, but the one for the petrol is much cheaper in Greece. Still, it is expensive, but you get a Hartge product, for whatever that means to each one of us.
| 05-31-2012, 12:27 PM | #11 |
Rep 908
Drives: F90 M5
It really is expensive, and if you had a 120d it would be a no brainer to get the BMW approved kit instead. However, BMW dont make a kit for the 125d yet -I hope they do soon though!
| 06-01-2012, 02:35 AM | #12 | |
Rep 485
| 06-01-2012, 03:24 AM | #13 |
Rep 216
hehe I actually went to check the price at the german bmw page aswell after I posted and noticed the huge difference in price!! perhaps it's possible to find an even better price in other countries. Seems like not all countries display the price though.
| 06-01-2012, 05:24 AM | #14 | |
Rep 859
In Norway the offer from BMW was NOK 19 860,- (EUR 2 600) incl. work. So now we know where NOT to buy. I don't think we will find much lower price than in Germany (995 + work), besides it would make fun to drive there and get the job done ![]()
| 10-17-2012, 05:47 AM | #15 |
Rep 26
Here in Turkey there is approx. 3.400 euros ( including taxes ) between the prices of 116i and 118i..
So,in my opinion; Paying more than 1.000 euros is much more unnecessary for power upgrading of 116i to 118i levels.. Both for powerbox or chip tuning ( re-mapping ) i will wait unless the prices will come down to my limits
F20 116i Sportline Deep Sea Edition
| Bookmarks |
