08-23-2019, 01:47 PM | #1 |
¯\_(ツ)_/¯
950
Rep 1,763
Need help with triple monitor setup (SOLVED)
Hey guys. I'm trying to finally get 144hz on all three of my Asus VG248QE monitors paired with my PNY GTX1060 6GB XLR8 card. I tried different cable combinations and it won't allow the last monitor to stay at 144hz. I tried 3x DP, 2x DP 1X DVI+, 2x DP 1X DPtoDVI, 1x DP 1x DVI 1x DPtoDVI.. you get the gist. All drivers up to date.
Any advice to get that third running 144hz would be great. Thanks. https://www.pny.com/geforce-gtx-1060-xlr8-gaming-oc https://www.asus.com/us/Monitors/VG248QE/
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC Last edited by Solidjake; 08-24-2019 at 09:18 PM.. |
08-23-2019, 09:18 PM | #3 |
¯\_(ツ)_/¯
950
Rep 1,763
I tried and it did not work. I forgot to mention that the DP on the third monitor is not working for some reason... So when I used DP (on the gpu) to DVI on that monitor the monitor does turn on and work capped to 60hz but plugging in DP-DP it has no signal. I might have to borrow my friends monitor and see if it's the monitor. ffs
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
08-23-2019, 10:05 PM | #5 |
¯\_(ツ)_/¯
950
Rep 1,763
Tried that. Set the other two lower and the third is still capped to 60hz. It won't even give me any other option than 60hz.
08-24-2019, 12:31 AM | #6 |
i'm just saying
5766
Rep 2,634
when they re all double linked, and when you lower the resolution if it still doesnt give you higher hz.. then its probably the limit of the card or the combination limit.. to verify you might contact Asus..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
08-24-2019, 10:47 AM | #7 |
Rep 2,362
A similar problem, but he has a 1080 and solved it by windows update.
https://www.nvidia.com/en-us/geforce...tors-at-144hz/ |
08-24-2019, 09:18 PM | #8 | ||
¯\_(ツ)_/¯
950
Rep 1,763
m4space6.00 |
