BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > steering wheel bmw m4 in bmw f21
      11-23-2015, 02:25 PM   #1
r0b3r
Drives: Bmw F
Hello, I need your help , I have a BMW Series 1 2014 f21 late December with M package, has this flyer :
http://i59.tinypic.com/qn5jwl.jpg
I want to put the wheel of BMW M4 , wanted to know if they are worth my cable , my bag and my steering wheel controls , and would have to do to get it ?
I want to buy on EBAY brand new and I find none of BMW brand new m4 .
You can help me ? thank you.
      11-24-2015, 05:15 AM   #2
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Straight swap -
Disconnect battery before removing airbag
Remove airbag
Remove SW from the car
Remove trims and switches
Refit same switches and M4 trim onto M4 steering wheel
Install M4 SW onto the car
Refit your original airbag
Reconnect battery.
Enjoy your M4 SW !!
BP
Current '22 X3M LCI..
      11-24-2015, 06:17 AM   #3
r0b3r
Drives: Bmw F
Originally Posted by Bee Pee View Post
Straight swap -
Remove airbag
Reconnect battery.
Enjoy your M4 SW !!
BP
That means that I serve as my both my AIRBAG multifunction controls? It refers to when he says cut? to be cut?
I do not understand the way you say: Refit same switches M4 and M4 onto steering wheel trim, which I have to cut?
I saw on the cutting wheel bearing m4 foam (reference number 8 in this link, http: //www.etk.cc/bmw/EN/search/selectCar/F82/Cou/BMW+M4/ECE/32/ 32_2302 / # 04) is necessary to buy?
      11-25-2015, 01:32 PM   #4
r0b3r
Drives: Bmw F
yes
      11-26-2015, 01:02 AM   #5
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
You re-use the switches from your existing wheel by fitting them onto the m4 steering wheel.
      11-26-2015, 08:33 AM   #6
r0b3r
Drives: Bmw F
Thanks very much !
      12-12-2015, 04:50 AM   #7
r0b3r
Drives: Bmw F
finish install !! good !!
      12-12-2015, 06:17 AM   #8
RiczPT
Drives: F21 118d
Please post a tutorial on this!
      12-18-2015, 10:27 AM   #9
juniortabak
juniortabak's Avatar
50
Drives: M135i
You Steering wheel photo is not an M4 its M package Steering wheel.
      12-18-2015, 11:11 AM   #10
Kannu
Drives: F20 120d M sport
Is the newer M wheel larger in diameter than the original? They look huge.
      12-19-2015, 06:42 AM   #11
r0b3r
Drives: Bmw F
The same two diameters. Only changes are exactly the same color stitching m .
