BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Alpine Audio Upgrade
      05-08-2012, 04:25 AM   #1
JonF1982
JonF1982's Avatar
Drives: F20 116i Sport - Crimson Red
I'm entertaining the idea of getting the Alpine audio upgrade. Does anyone have any experience with this on the F20, or the E8x models?
What could I expect to gain from upgrading? Is it worth it, etc. Any other related advise also welcome.
Car history:
116i Sport 5 door Crimson Red 2012 -
120i M-Sport 3 Door Le Mans Blue 2009 - 2012
      05-08-2012, 04:42 AM   #2
iBeech
iBeech's Avatar
England
109
Drives: BMW 520D F11 2015
I haven't done the upgrade myself- but after looking at what's included, and reading other reviews (the alpine kit is the same on all bmws) I'd say it's a kick as upgrade.
Things to note. It'll take 2 1/2 hours for a dealer to fit + coding. High will cost £200-400 extra. Fit it yourself then get them to code it.
Keep us posted- I want to do this upgrade as well
      05-08-2012, 04:59 AM   #3
JonF1982
JonF1982's Avatar
I'll ask the dealler for a quote including fitting and see what they say. If its that much though i might have to put it off until after the Holiday is paid for! lol
Car history:
      05-08-2012, 05:30 AM   #4
iBeech
iBeech's Avatar
England
109
Well, a dealer charges £100 per hour, 2 1/2 hours fitting, and I saw someone on here say it took several hours to code the car.... plus the unit is 390 + 60 for the two door sills for tweeters.
Let me know what your dealer says
      05-08-2012, 10:21 AM   #5
airblade550
Drives: F20 118D Auto Mineral Grey
Hi... Having fitted the Alpine upgrade to a late, (2010) E87 I can report that it was a complete "plug & play" installation procedure and took me appx 2.5hrs. I wouldnt imagine that it would be too much different on the F20
All that was needed were a few basic tools to unclip/unscrew a few bits of trim. The cables plugged into existing sockets in the loom.
As the signal is taken from the existing loudspeaker cables, (as opposed to the head unit at line level), the system sees no change, no new hardware is detected, so no coding is required at that level. The only instance where coding could be required is where, (because the basic system has no tweeters), the high feq output of the head unit has been boosted and needs to be set at a reduced level to reflect the new improved caperbilities of the retrofit.... Alternativly, just reduce the treble manually via the tone control...
The change to the system in quality terms is well worth the £350 that the kit cost.
      05-08-2012, 10:57 AM   #6
iBeech
iBeech's Avatar
England
109
In order to see (hear) the full benefit of the alpine upgrade, you must recode your car to disable the head units built in equaliser-if you dont it will go through a 2 phase equalisation; which equals reduced quality of sound.
Re-coding turns the head unit into 'HiFi' mode (a specific Alpine HiFi mode), which lets the amp do the equalisation, instead of the head unit.
      05-09-2012, 05:33 AM   #7
JonF1982
JonF1982's Avatar
The quote i've been given is £859.20!
I think that's pretty ridiculous so won't be going ahead.
Car history:
      05-09-2012, 06:38 AM   #8
iBeech
iBeech's Avatar
England
109
Whats the breakdown?
i'd guess:
£445.2 for the parts (assuming no discount)
£414 for labour
Did they break down the labour charges? I guess they've said 2.15 hours for fitting and 2 hours for coding. Please let us know. If you fitted it yourself, you could save £214
      05-09-2012, 07:14 AM   #9
JonF1982
JonF1982's Avatar
I didnt get a breakdown, just a headline figure. I told them i wasnt interested at that price.
I wouldnt feel happy about fitting it myself.
Car history:
      05-09-2012, 07:41 AM   #10
iBeech
iBeech's Avatar
England
109
Fair enough fella!
      05-09-2012, 08:31 AM   #11
Sonnig
Drives: F20 118i Sport
Wow, that's expensive. I wouldn't go for that.
A bit regret not getting the HK as factory fit.
      05-09-2012, 09:38 AM   #12
JonF1982
JonF1982's Avatar
Me too.
Car history:
      05-09-2012, 09:45 AM   #13
JonF1982
JonF1982's Avatar
Is the Alpine route the only way to go?
Car history:
      05-09-2012, 10:04 AM   #14
iBeech
iBeech's Avatar
England
109
without cutting wires, yes- for now.
blanpunkt do a plug & play amp- but not heard of anyone using it in an F20 yet.
You need the amplifier and the harness...
Amplifier:
http://www.blaupunktdirect.co.uk/inc...amplifier.html
Harness:
http://www.blaupunktdirect.co.uk/inc...or-cables.html
Although this will only upgrade the amp (Which should make a difference) you'll also want to upgrade your mids and possibly add tweeters to the front and / or back.
Something like this
http://caraudiosecurity.com/shop/pro...ts_id/508.html
      05-09-2012, 10:33 AM   #15
JonF1982
JonF1982's Avatar
Its fitting really that's the issue. If i could get the Apline unit through BMW then find someone to fit it for a more reasonable price, that would be ideal.
Car history:
      05-09-2012, 10:41 AM   #16
iBeech
iBeech's Avatar
England
109
If it was me, I'd buy the kit and fit it a bit at a time. probably start with the window trims / mids and tweeters. Once that's done, running the wiring through the car is the next step.
The main thing to keep in mind with this system is that it's all plug and play- no wire cutting! BMW will even provide you the instructions. Hell, ask for a copy of them before you buy, to make sure your completely happy first.
      05-09-2012, 11:13 AM   #17
JonF1982
JonF1982's Avatar
The thought of having to remove bits of trim scares me! lol.
My bro gets his new 3 series next week which has the Harmon Kardon system in. I'm going to see what that sounds like, i know its a different system but will give me an idea of what an upgrade might do for me.
I might also ring round the dealers and see if i can get a better price for fitting. I don't see why i should have to pay any more than £600.
Car history:
      05-09-2012, 12:16 PM   #18
iBeech
iBeech's Avatar
England
109
it will blow you away at the very least i want to add tweeters to my rig
      05-09-2012, 01:12 PM   #19
JonF1982
JonF1982's Avatar
Well ill have a good chance to listen to it when we cruise down the motorway to take in the DTM at brands hatch next weekend
Car history:
      05-10-2012, 09:39 AM   #20
iBeech
iBeech's Avatar
England
109
Just confirmed through a reseller that the following will work in an F20:
Blue Magic TL 130
THA 475 PnP - Plug & Play amplifier
THA Plug & Play amplifier adaptor cables
THA Plug & Play amplifier extension cables
In total, coming out at a respectable £319.96 + shipping, which i suspect would be free on an order that size
      05-10-2012, 10:03 AM   #21
JonF1982
JonF1982's Avatar
This looks cool, nice work!
Now if only i knew what i was doing maybe i could fit it! lol
Do you think a 3rd party garage might do fitting? There's an independant garage on my way to work that specialist in 2nd hand BMWs only. I wouldn't be suprised if some of the guys there are ex main dealer.
Car history:
      05-10-2012, 10:11 AM   #22
iBeech
iBeech's Avatar
England
109
np
i think a 3rd party would probably install it for you....
