BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Turbo Pipe broken with drivetrain warning
      01-30-2018, 08:14 AM   #1
conmaglh
Drives: 118i
Na
      01-30-2018, 08:19 AM   #2
What kind of engine do you have? N13 og B38?
      01-30-2018, 04:32 PM   #3
No one
Drives: F21 118i
N13. Why? You know them both, don't you?
Originally Posted by conmaglh View Post
how i could turn it off?
Cut the red wire (a joke!) :
Seriously, I would suggest you didn't fix it. If you are sure you did then yes, try to code it off (to make sure you are wrong ). Disconnecting the battery for half-an-hour should be a waste of your life time, but you can try to prove me wrong too.
      01-30-2018, 04:59 PM   #4
Yes, I do (not well enough to tell from the picture). But I wanted to know if this was something that is likely to happen on the engine I have now or not. I have seen it before on the N13, but not on the B38.
Some system faults will go away by themselves after a number of starts with no issue. I don't know if this is one of them.
      01-30-2018, 05:02 PM   #5
conmaglh
Drives: 118i
My engine is N13, 118i F20, and I found that I must use software tool to clear the engine alert, that’s much easier without touching other parts of th car. Thanks for your help.
      01-30-2018, 05:13 PM   #6
No one
Drives: F21 118i
"You can run but you can't hide". You have it on the B38 as well: http://www.realoem.com/bmw/enUS/show...diagId=11_5987 . Take good care of it. I've never seen it before so hopefully it's not a common failure.
