BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F87 M2 Airbox into F21 M135i - does it make sense?
      03-22-2024, 10:49 AM   #1
mc2226
Drives: e91 330xd; F21 M135i
Hi,
I'm playing with the idea of using a M Performance air box in my 2014 F21 M135i, as it's MHD Stage 2 and maybe it could use more air.
My question is: Has anyone of you tried it and can definitely say, that it was beneficial to use the M2 airbox, as it's less restrictive?
That's the one I'm talking about:
thanks in advance!
Ben
      04-15-2024, 07:35 AM   #2
luca.aluigi
luca.aluigi's Avatar
Italy
Drives: M135i F20, Maserati Biturbo
Hi there, i installed the M2 lower section airbox (included even on F30 MPPK), for 1 year now. Is not a night and day difference, but better throttle response and more vigorous high end, regard the cons a little bit increse in IAT about 2 or 3 deg Celsius. I run stage 1 MHD, this modification is cheap and has a good value for money, if you plan to go stage 2 i suggest you directly a complete CAI like Eventuri.
Are important modification in the induction system fluid dynamics also the Turbo intake Pipe, Intercooler and charge pipe.
2015 BMW M135i F20 LCI, man box, adaptive, HK, decat, MHD Stage 1, F21 underbrace retrofit, MP LSD, M4 LCA & TS, M Performance BBK, MSL oil Tstat, MPPK Airbox, CDV delete, Wagner EVO II, FTP CP, MST V2 turbo inlet, M2 sump and pumps.
... "beauty is the splendor of truth"...
      04-21-2024, 03:14 AM   #3
mc2226
Thanks for the report. That helps a bit with deciding what to do next
