BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 door squeaks
      02-24-2013, 02:33 AM   #1
Bruno28
Drives: 125i F20 M-Sport
F20 door squeaks - FIXED!
Hey,
Do any of you guys get door squeaks, mostly on the rear doors. Sounds like the leather seats, but are on the doors. I had similar problem with the E87 130i.
Any solutions?
      02-24-2013, 04:55 AM   #2
orcomma
Dividing by zero
orcomma's Avatar
Drives: F48 X1 XDrive20d xLine
gummi pfledge on the window rubbers works a charm
      02-24-2013, 04:57 AM   #3
A common source for door squeaks in modern BMWs is silicone on the door gaskets.
      02-24-2013, 06:22 AM   #4
Bruno28
I have that, do you mean on the window rubbers around the window or the one that seals the doors?
      02-24-2013, 06:23 AM   #5
Bruno28
So avoid use of any silicon on the rubber seals?
      02-24-2013, 06:42 AM   #6
Yes. Silicone remover usually does the trick. Use only silicone free agents on the seals. I think BMW has their own treatment you can order.
      02-25-2013, 09:25 AM   #7
Gras
Greece
Drives: F20 116i, Urban, Auto
What do you all mean by silicon remover? Some people suggest to apply silicon spray to remove squeaks (?).
      02-25-2013, 09:52 AM   #8
orcomma
Dividing by zero
orcomma's Avatar
window rubbers, i had the exact problem you had, twas the window rubbers
      02-25-2013, 09:54 AM   #9
That is not a good advice for BMWs, and usually what's causing the squeaking in the first place.
Notice the difference between silicon and silicone.
      02-25-2013, 03:10 PM   #10
Bruno28
Sorry, english is not my native language.
      02-25-2013, 03:11 PM   #11
Bruno28
Ok i will try and fix this problem
Thanks
      02-26-2013, 01:06 AM   #12
Fanis
Fanis's Avatar
Greece
53
Drives: 116i (F20) Auto
Never use silicon spray on the seals, only silicon-free products, like Gummipflege.
2011- : BMW 116i (F20)
2009-11: BMW Z4 2.5si (E85)
2007-09: Mini Cooper S (R56)
2005-07: BMW 325ti (E46)
2004-05: BMW 318i (E36)
      02-26-2013, 02:30 AM   #13
ttimbo
ttimbo's Avatar
282
Someone once told me that ...er...personal lubricants work well, but I have no comment!
      02-26-2013, 02:46 AM   #14
happyJoylucky
Drives: F20 125i Sport
Is your car still under warranty? If so, see if you can get your dealer to check it out.
      02-26-2013, 05:15 AM   #15
Bruno28
Hahahahah
      02-26-2013, 05:16 AM   #16
Bruno28
Yes it's a 2012 model so still under warranty. But if the gummi works I'll just use that instead of taking to dealer and spending hours there
      03-03-2013, 02:24 AM   #17
Bruno28
Ive put Gummi on the window seal, but the sound continues.
SHould i try the door seals with Gummi?
      03-04-2013, 03:32 AM   #18
Bruno28
FIXED!!!!
use Gummi and put it on the top furry part of the door seal. The rubber that goes around the top part only of the door seal. Not a squeak now
      03-04-2013, 05:24 AM   #19
tawia
tawia's Avatar
Drives: F21 125d
I had this before. Last owner had a valet and rubbers cleaned with silicone. Doors jiggled for months. Took about 6 months to treat even after using silicone remover. Done my head in at the time
      03-05-2013, 08:06 AM   #20
MartinHattingh
MartinHattingh's Avatar
South Africa
22
Drives: 2012 X3 XDrive 2.0i
I have a fairly simple fix. Ensure that all the paintwork touching seals is waxed and thus super slippery. Works like a charm.
      03-06-2013, 10:26 AM   #21
116d_newbie
Drives: F20 116d Efficientdynamics
I have a similar problem. Will try your solutions. Thanks!
      03-14-2014, 11:02 AM   #22
Arrow29
Drives: M2 comp, X5 M50i ordered
I've started getting this on mine
I've read elsewhere that some recommend Autoglym vinyl and rubber care, however searching their website they state that this contains silicone which seems to be a no no? A shame as there is a Autoglym stockist down the road from me, but if I want to get gummi pflege I need to order from interstate (I'm in Perth, Australia) which will take a week or so to arrive.
Might have to order some and give it a try, bit annoying on a <6 month old car! Half tempted to just take it to the dealer, but a hassle to be without the car etc if I can fix it myself.
