BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > How To Take Advantaje Of The Infotainment In A F21
      01-16-2014, 07:56 PM   #1
bimmerblanco
Drives: BMW F21 2014
Hi, as I mentioned 2 months ago, I am a happy owner of a 2014 F21 118i steptronic. My car doesn´t have navigation (it doesn´t have the wide screen either). I am having trouble communicating mi iphone 4s with the car. I connect it via the white stripe of the iphone in the usb port of the central and launch on the iphone de BMW Connected app. It doesn´t connect. I make the connection diagnosis and I get no answer (no connection).
Do you know how can I make this work? Is really the bmw connected app useful? I can see my twitter and FB account in the screen without having the navigation version?
Thanks a lot for your comments!
      01-17-2014, 04:58 AM   #2
Bob UK
Drives: 2013 X1 18d X-Drive
Not sure but I believe you need the correct "Y" cable are you using this?
      01-17-2014, 05:59 PM   #3
Andoni.F20
Drives: AW 118i F20
se me hace muuuy raro, yo tambien tenia el mismo "combo", solo q f20 con iphone 4s y ningun problema al conectarlo con el cable, si es el cable original apple? por que algo lei que con el ios 7, todos los cables no originales no funcionarian
aqui la nota, http://readwrite.com/2013/09/24/ios-...otfxq0TXdYiMcv
      01-17-2014, 06:01 PM   #4
Andoni.F20
Drives: AW 118i F20
tambien la funcion de FB y twitter cuestan como 200dllls me parece que si se puede hacer un retrofit, si es q no lo elegiste como opcion desde un principio
      01-24-2014, 03:08 PM   #5
bimmerblanco
Hi! Yes i´m using the original USB cable that comes with the Iphone 4S, not I´m not using the Y cable... where do I buy this cable and what´s the difference with the standard apple cable?
This week I configured my car to play music via bluetooth (that´s nice) but I have no illustration of the disc in the screen.
So, what are the real advantaje that i will get if I buy the Y cable... what featres I could get?
      01-24-2014, 09:24 PM   #6
Andoni.F20
Drives: AW 118i F20
If you use bluetooth, the album cover is not available, only by usb connection
you dont need the Y cable, that was for the earlier models, but if you wanna try it, you can get it at your bmw dealer, for about 100 usd
but as i told you there's no need to do that, since my iphone 4s and my 2014 f20 worked just about great!!! you should try with another iphone, or take it to the dealer to have them check
im now using a iphone 5c through usb and work flawlessly with itunes app and spotify!
Im at guadalajara, so if you are here too, maybe we can met, and see what's "wrong" with your car!
