10-21-2014, 03:26 AM | #1 |
Rep 5
BMW F21 with F22 M-Technic front
Wanted to share this since I really think this makes a huge difference on the overall look of the BMW F20 / F21
This project was made by our department in the Netherlands together with the company Wrapaholic Here the BMW F22 M-Technic front is being mounted. The BMW was wrapped in foil at the company Wrapaholic, the color is red matt metallic. The BMW'en was revealed at 100% tuning by Kenneth Olsson manager at Schmiedmann Netherlands together with Liesette Braams who is a driver for the Las Moras Racing Team in the GT4 Europeen Series, where she drives a BMW M3 GT4 Moments before the unveiling of the styled BMW F21. The final result On each side of the hood the Schmiedmann logo was embossed in the foil. Images of the styled BMW F21 outside. The following parts was mounted on the F21 COVERING RIGHT Order no. 51-43-7-055-434 PANEL, BUMPER, PRIMED, FRONT Order no. 51-11-8-057-047 FLAP, TOWING EYE, PRIMED Order no. 51-11-8-058-061 COVER, SPRAY NOZZLE, PRIMED LEFT Order no. 51-11-8-058-871 COVER, SPRAY NOZZLE, PRIMED RIGHT Order no. 51-11-8-058-872 AIR DUCT, BOTTOM Order no. 51-74-7-290-604 AIR DUCT, RADIATOR Order no. 51-74-7-290-605 AIR DUCT, BOTTOM Order no. 51-74-8-058-911 AIR DUCT, BRAKE, LEFT Order no. 51-74-8-054-415 AIR DUCT, BRAKE, RIGHT Order no. 51-74-8-054-416 GRILL, BUMPER, W/ FR. FOG LAMP, FR. LFT Order no. 51-11-8-055-319 GRILL, BUMPER, W/ FR. FOG LAMP, FR. RGT Order no. 51-11-8-055-320 PRESSURE LIP SEAL, FRONT LEFT Order no. 51-74-8-060-799 PRESSURE LIP SEAL, FRONT RIGHT Order no. 51-74-8-060-800 BI-XENON HEADLIGHT, LEFT Order no. 63-11-7-388-927 BI-XENON HEADLIGHT, RIGHT Order no. 63-11-7-388-928 FILLISTER HEAD SCREW Order no. 07-14-7-288-888 SELF-LOCKING HEX BOLT Order no. 07-14-6-961-201 LINSENSCHRAUBE MIT LOSDREHSICHERUNG Order no. 07-14-6-978-618 ORNAM.GRILLE, HIGH-GLOSS, BLACK, FR.LEFT Order no. 51-71-2-336-815 ORNAM.GRILLE, HIGH-GLOSS, BLACK,FR.RIGHT Order no. 51-71-2-336-816 FOG LIGHTS, LEFT Order no. 63-17-7-839-865 FOG LIGHTS, RIGHT Order no. 63-17-7-839-866 SET OF LED MODULES, LEFT Order no. 63-11-7-388-923 SET OF LED MODULES, RIGHT Order no. 63-11-7-388-924 |
10-21-2014, 06:35 AM | #2 |
Rep 48
I've to say it looks DOPE!! It's one of the most beautiful 1 series i've ever seen, nicely done!!
Which parts do i need additionally, besides 2 series front bumper, headlights & grill to make it look like the 2 series? Does these parts fit to the F20 front? |
10-22-2014, 02:08 AM | #3 |
Rep 5
The list of parts I have put in the post is what our department in the Netherlands used for the conversion so that should basically be it. The F20 / F21 / F22 all share the same hood and front fenders so this modification should also be possible to make on a F20. The only thing to note here is that the headlights on this modification is bi-xenon headlights and if if you have headlights without xenon you'll need the standard F22 headlights instead.
http://www.schmiedmann.com/en/produc...3-11-7-304-461 http://www.schmiedmann.com/en/produc...3-11-7-304-462 |
10-22-2014, 05:54 AM | #4 |
Rep 47
Schmiedmann looks pretty nice. I still prefer the 1 series having a unique look to most of the bmw range though even with those angry bird lights! Dont get me wrong this update on the car looks awesome but not sure if I would go to those lengths to change the look of the front end. Excellent work though and a fantastic result
10-22-2014, 09:15 AM | #6 | |
Rep 4,525
Current '22 X3M LCI.. |
10-23-2014, 02:34 AM | #7 | |
Rep 48
This guy in Germany has been through the same process. He says that coding and programming was a bit challenging rather then installation. |
10-25-2014, 04:03 PM | #8 |
Rep 9
I've done the Sport -> M Sport conversion on mine, this is rather tempting for a second change.
It seems relatively straightforward - bit what are the pressure lip seals please? |
10-26-2014, 08:52 PM | #9 |
Rep 1,233
Nice, I do like the rear look with the four pipes and the blacked in front air scoops
Probably not the colour I would have chosen. I wonder what it would have looked like in brushed Titanium By the disc size, I gather it started out as a 116i/118i It needs the M brake package to really finish it off. |
10-28-2014, 05:37 PM | #10 |
Rep 5
i got the same conversion on mine
but the eyebrow lights and adaptive headlight didn't work on it anyone can help on it? thanks Last edited by pp1024; 10-28-2014 at 05:44 PM.. |
10-29-2014, 01:29 AM | #11 | |
Rep 48
11-15-2014, 09:40 PM | #13 |
Rep 1,233
To get the eyebrows working you have to have the module behind the lights coded to sinc with the main lighting control unit. (as long as the wiring loom is correct)
11-20-2014, 07:11 PM | #14 |
Rep 2,182
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
Wow this is so extensive. Good job!
But this makes me appreciate the unique 'bug-eye' design of the F20. Strange huh?
Current:
2022 G01 BMW X3 xDrive 30d 2018 8U Audi RSQ3 2017 F55 Mini Cooper S 2015 F22 BMW M235i |
08-03-2015, 01:12 AM | #16 |
Rep 1,233
08-18-2015, 06:09 PM | #19 |
Rep 1,233
Seems to be a trend happening here.
They all look great. Perhaps BMW needs to look at what their 1er owners are doing to inspire them when considering future designs |
05-13-2017, 07:18 AM | #20 |
Rep 8
Hi all - this is my first post!
I have an F21 with the F22 conversion done.. Its was done before i bought and the prev guy made a horrific job on the headlights and i need help...! Everything works apart from the full beam / flash - so i have some questions.. The car came with LED headlights new - and has the LED F22 Headlights in also.. are there two LED bulbs or does one do everything? Can anyone recommend anyone in the UK who could help me sort it? Have attatched a picture for reference Thank you for reading! https://www.dropbox.com/s/v1vzw68ghy..._2139.JPG?dl=0 Last edited by JohnBoyMinster; 05-13-2017 at 07:28 AM.. |
05-15-2017, 04:26 PM | #22 |
Rep 8
Thanks so much for your reply.
Ah ha!! This explains a lot... my car car came with LED lights from the factory. This must be why they won't work properly then... Is it that I need to buy LED headlights in this case? The last guy must have done some serious bodging to get this working as the car will have wiring for LED?!! EDIT - I've just been googling and it looks like no LED option on the F22? God I'm confused!!! Last edited by JohnBoyMinster; 05-15-2017 at 04:49 PM.. |
Tags |
f22 f21 |
