BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Battery disconnection query
      11-07-2015, 03:03 PM   #1
LukeS1994
Drives: F20 116i MSport 2013
Hi all,
Real quick question I'm removing the steering wheel on my car tomorrow and therefore disconnecting the airbag on the steering wheel.
I'm going to disconnect the battery beforehand obivously but I've read different things all over the internet so can somebody help.
Do I disconnect only the negative? or disconnect the negative then the positive (so both) ?
Sorry to sound novice but alot of people just say disconnect the negative but what is the difference
Thanks in advance I'm sure this question will get cleaned up pretty quickly
      11-07-2015, 03:20 PM   #2
It is enough to remove the negative terminal. Then all circuits in the car will be broken. Removing the positive terminal after that will not make any difference.
Just be careful when connecting the negative terminal again.
      11-07-2015, 03:33 PM   #3
LukeS1994
Originally Posted by LukeS1994 View Post
Hi all,
Careful in what sense? I am careful just wondering if theres anything to pay close attention to when reconnecting.
      11-07-2015, 03:41 PM   #4
It will make a small voltage shock in most circuits, and maybe a spark where you connect. Don't have anyone sitting very close to your airbags at that moment, just in case.
      11-07-2015, 03:53 PM   #5
LukeS1994
Good point Ill certainly make sure nobody is sitting near the airbags
      11-08-2015, 04:02 AM   #6
LukeS1994
Thanks for that it did spark as you said but all is well
