BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Query on removing Adaptive M running gear
      08-21-2013, 03:02 AM   #1
1bmwJ
Drives: M135i
Commonly known as the Adaptive suspension, has anyone one swapped it out for a set of coilovers? Even in sport mode it' s a tad too soft for my liking.
I am not sure if it can be done. How complicated is the procedure and what is required? ( cancellers, coding, etc.).
      08-23-2013, 05:39 AM   #2
morita76
Drives: 11 STI
I heard that there are KW V3 that can be used with the adaptative damper controls, but I couldn't find the partnumber
      08-23-2013, 10:53 AM   #3
Chris in Japan
Drives: BMW M135i on order
kw ddc coilovers
kit no.: 39020018
those should be the ones that work with the adaptive. Very cool kit just google KW DDC for more info.
I almost ordered them, but went with a racing dynamics kit instead.
Cheers
      08-23-2013, 07:52 PM   #4
morita76
Drives: 11 STI
Originally Posted by Chris in Japan View Post
kw ddc coilovers
kit no.: 39020018
Cheers
Are you sure that is fits f20? Seems to be for F30, do F20 and F30 have identical suspension?
      08-27-2013, 06:45 AM   #5
1bmwJ
Drives: M135i
Anyone has done this yet? Or do lowering springs help the body roll significantly?
      08-27-2013, 08:44 AM   #6
Stiff springs will always reduce body roll. So will stiffer dampers, which are mandatory for stiffer springs.
How significant the change is, depends on how stiff suspension you buy.
