BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > M135i tow bar
      08-19-2013, 02:22 PM   #1
scottmmw
Drives: BMW M135i
M135i tow bar
Hello, does anyone know if a tow bar can be fitted, would like one to my bike on the back if possible, the manual suggests 1500kg towing capability so I presumed one can fitted.
Thanks, Scott
      08-19-2013, 03:33 PM   #2
pron
Drives: 125i M sport
You can't select a towbar in the configurator on the M135i as you can on the 125i.
      08-19-2013, 03:43 PM   #3
Math
Math's Avatar
Belgium
Drives: BMW F21 116D
I noticed this too. Just like on the 116ED, but on my car I know its because the 'eco' gearbox can't handle the added weight of a heavy trailer. I dont really know why the 135i should't be allowed to tow anything. Sure its got more than enough power... But maybe its also gearbox-related..
2012 - BMW F21 116D ED
Please check my amazing car rental website at http://www.bscc.eu!
      08-19-2013, 04:32 PM   #4
pron
I think it's maybe the rear exhaust section that get in the way. I don't imagine the automatic gearbox are a problem. I have a towbar on my 125i with the 8-speed, and it's rather cramped back there.
      08-19-2013, 05:13 PM   #5
Bradbury
Vroooooom!
Bradbury's Avatar
Drives: F20 120d
Isn't the exhaust on the 335i pretty similar to the M135i? You can get a towbar of the former.
      08-19-2013, 10:16 PM   #6
It is quite common for BMW to not offer tow bars for M-cars.
You can however fit aftermarket tow bars on most of them, and probably even BMWs own.
      08-20-2013, 10:33 AM   #7
pron
Yes, but the 335i is larger car with more space behind the wheels.
      08-20-2013, 10:33 AM   #8
pron
You can order a tow bar for the new M5.
      03-08-2015, 09:23 PM   #9
drmoose
Drives: F20 M135i manual
Thought I'd pipe in here as there's so much misinformation on the towbar on M135i particularly with people thinking you can't have a towbar due to space limitation from exhaust
After about 6 months of looking for someone to install one and being told "not available". I've just had a heavy duty Hayman Reese towbar fitted to mine in Sydney Australia without a single problem. 125kg vertical weight and 1200kg towing capacity. Removes/installs in about 30 seconds.
The model from Hayman Reese was simply for the F20 125i.
http://www.haymanreese.com.au/produc...owbars-class-4
Installed by Rallyspeed in Sydney with full electronics.
      02-17-2016, 10:48 PM   #10
Ascm135
Drives: M135 LCI
Hi Drmoose
Do you have any photos of the towbar in your car?
Is it completely hidden when the tongue is off?
Cheers
      01-17-2019, 12:05 AM   #11
bm49
Drives: 2012 135i manual, 2010 320d
This is all consistent with my experience in fitting a 125i bar to my E82 135i some years ago.
My daughter is about to take delivery of a 2018 M140i and would also like to fit a towbar. Unlike my 135i I think the F20 M140i has a transverse muffler with left and right-hand tailpipes.; does anyone know if the 125i towbar will also fit OK on the later M cars?
      01-17-2019, 05:20 AM   #12
No one
Drives: F21 118i
Firstly a tow bar does not seem to need any fitting. Secondly, the equipment this tread is actually about is still not offered officially for M Performance cars: http://www.realoem.com/bmw/enUS/part...MW-M140i&mg=03. What's interesting is it's neither supposed for 125i LCI specifically in Australia: http://www.realoem.com/bmw/enUS/show...diagId=03_1046.
