BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Driver Restraint System Malfunction
      01-15-2019, 02:27 AM   #1
Glun34
Drives: 2014 M135I
Hi Guys,
Got the “Driver Restraint System Malfunction” error after retrofitting one of the newer style steering wheels to my 2014 M135I. I had the battery disconnected while installing it, but I think when I reconnected it and turned the ignition on the airbag connector wasn’t in properly and that’s how I got the code.
What’s my options for getting it cleared? It’s it a dealer only thing or can I use a generic code reader to get rid of it?
Any help it’s appreciated!
      01-15-2019, 02:32 AM   #2
You can clear it with some generic code readers.
      01-15-2019, 06:48 AM   #3
Glun34
Drives: 2014 M135I
The wheel I have has apparently come off an F30. I was told by the seller that it would fit my F20, but I’m starting to think I may have had the clip in correctly and maybe you can’t use the F30 airbag on an F20 without having the error?
      01-15-2019, 10:36 AM   #4
No one
Drives: F21 118i
Your predecessor did not complain.
      01-15-2019, 11:07 AM   #5
Glun34
Drives: 2014 M135I
That interesting. So it doesn’t make any difference if it’s come out of an F30, it should be fine on my F20?
      01-15-2019, 09:09 PM   #6
No one
Drives: F21 118i
Why? You should have wondered before retrofitting or "forever hold your peace". Perhaps.
Unless there's a more serious mistake than "From:07/01/2012 To:-" (Back to Diagrams says "From 03/2014") not the steering wheel itself (Did you know you chose wrong going with F20 rather than F21? ):
but the airbag module you suspect is the same:
Feel free to click "Back to Diagrams" or "Select another car" up there to refine your cross-referencing.
Yet, the steering wheels must be interchangeable as well, in fact, differing in some decoration(?) apart from weight only.
      01-16-2019, 06:22 AM   #7
emil111
emil111's Avatar
Romania
44
Drives: BMW 114d
There shouldnt be any problem retrofitting it,as far as im aware the f30 M steering wheel is the same as the f20’s....
And you can retrofit cleanly an lci M steering wheel on a pre lci vehicle without errors or anything
