BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > m135i vibration sound
      11-05-2018, 12:30 AM   #1
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
hi all
i have a 2014 m135i with 40000miles(64000km) with two separate issues i would assume
ISSUE 1
i have been getting this weird vibration sound(its sounds metallic) through out the rpm in comfort and sport mode and when the engine is hot and cold.
(BMW have checked the ASD and it is not the cause of this sound)
ISSUE 2
further to this i have another separate issue where the steering wheel vibrates at around 1000rpm and can be felt touching touching the body panels of the car as well. this vibration gets progressively worse as you accelerate through a corner at bit of pace and as the speed increases to 140kph where the car feels like the alignment is out ( i have just replaced all 4 tires with mpss and the alignment has been done twice in the past (60miles/100km)
bmw replaced the following to try fix the issue
the water pump
tappet cover and seal
oil pump
vannos seals
engine mounts
steering rack
vbelt and pulley
both problems still exist does any know or have any insight into what may be the cause? PLEASE HELP
Last edited by ChristosD; 11-05-2018 at 12:34 AM.. Reason: forgot to ask the community a further question
      11-05-2018, 12:42 AM   #2
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
The vibration from ISSUE 2 happens when in neutral with the car stationary so there's no load on the engine.The vibration always happens upon deceleration of rpm's also so as the car drops from 1100rpm the vibration can be felt.
could it be the exhaust rubbing or the guibo/center bearing or a crank balancer?
or is this bearing knock
      11-05-2018, 05:44 AM   #3
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
i just did a test if i put the car in neutral and hold it at 3500rpm the vibrations get worse
edit
i have just read a interesting forum on bimmerpost
https://f30.bimmerpost.com/forums/showth...p?t=949816
the problem could possibly be a low pressure ac pipe that is creating the vibrations. my vibrations get worse with the ac on vs off
      11-06-2018, 12:36 AM   #4
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
no one?
      11-15-2018, 11:59 PM   #5
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
BUMP..... please help.... anyone?
      11-16-2018, 02:08 PM   #6
No one
Drives: F21 118i
Well, all the rattle I can hear in the video appears to come from the "something" swinging on the mirror (You know that kind of things distract and fatigue the driver's attention, or so they say - I never tried that myself. But it's a different story, of course.). When looking closely I also had an instant impression it was related to that "thingy" down below that appears to move on it's own (If it's an MT lever where's the hand moving it?) but I'd really hope it's not.
So, did you suspect the cooling function? Say, turn the AUTO program off, turn the cooling off while the climate is on - any difference? Or did you mean "Air Cooling" over "Air Conditioning" already? Also, did BMW consider the A/C compressor?
      11-22-2018, 02:39 AM   #7
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
Well, all the rattle I can hear in the video appears to come from the "something" swinging on the mirror (You know that kind of things distract and fatigue the driver's attention, or so they say - I never tried that myself. But it's a different story, of course.). When looking closely I also had an instant impression it was related to that "thingy" down below that appears to move on it's own (If it's an MT lever where's the hand moving it?) but I'd really hope it's not. HAHA thats my water bottle
they did check this said its all fine
there was a part of the exhaust that was rubbing on the fire wall and they fitting a dampener or weight thing to the low pressure air con pipe (this pipe runs over the charge pipe they say this is likely the cause of my vibrations. i will get the car back today and see if the issue is fixed.
      12-14-2018, 11:43 PM   #8
lefthander
Drives: BMW F30
Did you solve this?
      12-16-2018, 11:42 PM   #9
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
hi yes the aircon pipe weight thing seems to have done the trick no vibrations for the last 2000km
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 //
      12-18-2018, 08:43 AM   #10
lefthander
Drives: BMW F30
The above link is dead, which Ac pipe is causing the vibration?
      12-18-2018, 01:18 PM   #11
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
this is the damper weight kit that was added onto the A/C low pressure line
part numbers:
weight 64539322952
hose clamp 07129952119
these are images i have taken from the thread below
https://f30.bimmerpost.com/forums/sh...d.php?t=949816
