BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 newbie questions
      02-02-2017, 03:17 PM   #1
Cetar
Drives: BMW F20 116i 2014 AT
Hi gents,
I have recently bought a F20 116i sport-line 2014 18000km and I have a few questions I would like you to answer please.
1) The car has strange tires not listed in the technical sheet or tire pressure sheet. The tires are Continental WinterContact TS 850 P RFT 225/55 R16 95H. Could you please suggest me the right pressure for them? Empty weight=1395kg., fully loaded 1885kg.
2) I am very disappointed by the fuel consumption. I was told the car is a small economical hatchback however the fuel consumption is about 9-10l/100km in comfort mode and driving really economical - 4-5 stars in EfficientDynamics analysis. In eco mode i have 8.4l/100km lovest. I drive about 2km urban, 8km extra urban and 2km urban again. That is a bit far from the value from technical sheet (5.6l/100km combined). Outside temperature is about 0 or a few deg. below. Tire pressure is 2.1 front and 2.3 back. Is it ok or should i check something?
3) When i shut the engine off by the start button, the radio wont switch off till i push the start button again. Is there a way to make the car shut down completely?
Thank you for your answers.
Cheers.
Martin
      02-02-2017, 04:44 PM   #2
emil111
emil111's Avatar
Romania
44
Drives: BMW 114d
question 3: as far as i can know you cant make it shut together with the engine....i dont understand why you would want it to......i always leave it running until i leave the car and close it
Bmw 114d
Honda Jazz
Daewoo Matiz
Daewoo Nubira II
      02-02-2017, 04:47 PM   #3
vladberca
vladberca's Avatar
Romania
763
When the engine is cold shift at lower RPM.
Like 2500. Until the water reaches the optimum temperature.
What's wrong with the tires?
      02-02-2017, 04:51 PM   #4
I would run 2.5 bar front and rear.
Our 116i with manual gearbox could do 5.0 L/100 km on country roads on long trips, but also up to 20 L/100 at track days. Urban driving and shorts trips will make the car thirsty.
Try to take your feet off the pedals, and click the start button again to switch off the ignition. If not, the radio will stop when you go out and lock the car, or if you wait a few minutes.
      02-09-2017, 04:32 AM   #5
xmaxnux
Drives: 116i Sport
Hello everyone, i'm new here and considering buy an F20 118i 2012 year, manual transmission with 82.000km(around 51.000 miles). Is there any considerations to know about the engine? Common troubles maybe?
Thanks in advance
      02-09-2017, 09:26 AM   #6
Weiman
Weiman's Avatar
Sweden
156
Drives: BMW 116i M-Sport -14
Not really, the N13 seems to be a very solid engine. It might rattle a bit at idle, but that's nothing to worry about as far as I know.
      02-24-2017, 05:59 AM   #7
jay0909
Drives: BMW F20 116I
F20 Black panel display
Hi,
I have 2013 BMW F20 116i. I have and old instrument cluster. I need to upgrade to the black panel display where i can see the GPS direction get more info about efficient dynamics. Does anyone know is to possible to upgrade ?
If any other alternatives please let me know.
      02-24-2017, 07:34 AM   #8
emil111
emil111's Avatar
Romania
44
Drives: BMW 114d
Originally Posted by jay0909 View Post
Hi,
It is possible to upgrade to the extended instrument cluster,i have seen it been done to other f20s but i do not know the procedure.....someone else might tell you
      04-01-2017, 02:34 PM   #9
surayne
Drives: M140i
Regarding question 3 - it is possible to code the car to switch off the radio when you open the driver's door, so you don't have to push the ignition button twice. I used the Bimmercode app on iOS with a vGate wifi dongle to do this, but you could use ESYS.
      12-28-2018, 09:40 AM   #10
cameron1810
Drives: BMW f20 118i
Coding Auto headlights using Bimmercode
Hi, ive had my F20 2 years now and have used bimmercode before, done a couple off things including cornering lights which never worked when i coded it, turned out the car has to have headlights set to automatic, my car doesn't have automatic headlights but i done the modification to the light switch to allow this. the cornering lights are now working and i have ordered the sensor to code for the automatic lights and wipers, what i want to know is am i able to code the new sensor to the car using Bimmer code. And also if i can code fog lights to come on with full beam. Thanks
      12-28-2018, 12:45 PM   #11
Fog lights and full beam? Why would you want that? I would assume that you want to see far ahead with full beam, and in that case, you want less light right in front of the car.
