BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > HK Audio - Enable EQ
      10-04-2017, 09:24 AM   #1
BimmerMad
Drives: 3 wheeler
Is it possible to enable the HK EQ via coding?
I?m coming from an F30 to an M140i and would like the EQ if possible.
I?ve read that you can code the following:
AUDIO_SYSTEM: hifi_system_harmankardon = 06
AMPLIFIER_VARIANT: most = 02
EXTERNER_MOST: aktiv = 01
Should those values not be the default anyway? How would that enable the EQ?
The 140i has HK and Pro Nav.
      10-04-2017, 11:04 AM   #2
eray
Turkey
20
Drives: 2014 Audi S3 Quattro 300 Hp
hi,
unfortunately it is not possible.
The HK system on your previous car consists of 16 speakers and 600 watt amplifier with so called logic7 surround. while the one on the F20 has 12 speakers and 360 watt output and offers no surround sound processor. They are two different systems. You just have to stick with factory settings
      10-04-2017, 11:05 AM   #3
BimmerMad
Drives: 3 wheeler
Originally Posted by eray View Post
hi,
I?m aware but apparently you can enable the EQ at least.
      10-04-2017, 01:32 PM   #4
eray
Turkey
20
there is no way to enable the eq in that setup.
      10-04-2017, 01:33 PM   #5
BimmerMad
Drives: 3 wheeler
Someone definitely claims to have done it.
