BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Where to hardwire my dashcam
      08-23-2015, 08:22 AM   #1
andru
Drives: BMW LCI 125D M Sport
I have purchased this dashcam https://www.lukashd.co.uk/LUKAS_LK_9750%20Duo_Pro.php and installed it almost completely now. I am struggling to think of where to hard wire it to. From my readings the car hibernates after about 15 minutes turning off power to sockets. Which would be the best way to get this hard wired as I want it recording as it is parked up also.
Thanks in advance
      08-23-2015, 08:33 AM   #2
I think the easiest way would be to use a battery bank that charges when the ignition is on, and powers the camera when the ignition is off.
      08-23-2015, 08:40 AM   #3
andru
Thanks for that suggestion but I don't really want to go down that route. I'd rather hardwire it to a constant live if i knew where one was.
      08-24-2015, 08:55 AM   #4
StrangeWorld
Drives: G29 M40i; G20 320e
You could try the installation instruction for the BMW Advanced security cam. It hardwires to the car battery.
https://www.google.com/url?sa=t&rct=...UGqBGK2grj_EQA
Can you make some pics in installing it? Curious to see if it easy fits in.
      08-24-2015, 10:25 AM   #5
andru
Thanks for that suggestion, I just bought some twin 0.75mm cable in the prospect of going straight to the battery. Weather permitting tomorrow, I'll have it all in place. All the camera cables for fron and back are in place it's just these final conections to do.
      08-24-2015, 10:42 AM   #6
andru
Just a few of the cabling.
      08-25-2015, 01:33 AM   #7
harkes
harkes's Avatar
China
1078
FYI
http://f20.1addicts.com/forums/showp...51&postcount=1
(A Dane in China)
      08-25-2015, 08:44 AM   #8
andru
All fitted and completely hard wired directly to the battery in the boot for the constant live and earth. I took the switch wire from the 12v socket under the front panel. All cables hidden behind all the panels etc on the passenger side. Even the DAB radio is working fine with it connected as I have read some stories where the instalation ruins the DAB signal. I'll put some pictures up as soon as I can. It was a real fiddle to do but worth it to do it right and get 24/7 protection.
      08-25-2015, 09:58 PM   #9
harkes
harkes's Avatar
China
1078
Did you also install a Battery Guard like the LK-290? If not you will likely find your car drained from power one day...
(A Dane in China)
      08-26-2015, 03:26 AM   #10
andru
I didn't need to as the LK-9750 has the battery guard fitted inside the camera. It is accessed by the on screen menu. I've got it set to 12.1v.
      12-30-2020, 10:53 AM   #11
deathmonkey
Drives: BMW 1 series (F20)
How long does the cable need to be?
