BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Bmw F20 2013 Upgrade To The Lci Front 2015
      08-18-2015, 06:43 PM   #1
alladin cars
Drives: bmw f20
Hi everyone
i bought a bmw 1 series f20 2013 with a side hit damage which now has been professionally repaired however i was able to get hold of a front end for very cheap with the new headlights in it,
i have done some reading and have come across a wiring harness for the bmw f30 but not for the f20
i am unable to switch the lights on.... off course as this may need to be hard wired and then coded, hopefully my ethernet to obd2 should be here in a few days,
can someone kindly shine some light on me as im absolutely stuck and non of the locals have a clue where to start from, so i thought maybe its something i can just learn to do myself.
attached is a pic of my front end conversion what do u think
116d auto
can i just say many thanks in advance
      08-19-2015, 01:50 AM   #2
dishy
Drives: M135i
I hope that cable tie is not holding the wheel on
I think it looks okay, from that angle the lines match up. But it may reduce the resale value of your car since it's now non-standard. You will have to inform your insurance of the modification and as such your insurance could be higher depending on who your insurers are and your policy. You also have a problem with the headlights as you say but hopefully that is an easy fix.
I'm not sure why the headlights are not working. In my mind, the front end would be just bulbs. Are they the same bulbs? Does the connectors to the lights fit? If yes, are the pin-outs the same? If not then I guess you will need to modify your F20 harness or make some kind of adaptor plug as an intermediary between your F20 haress and the new headlights, to save cutting your F20 harness and causing more issues down the line. Something like:
F20 harness > original headlight connector > adaptor wiring / plug > new headlight
      08-19-2015, 01:53 AM   #3
I think the resale value of F20 with that front would be somewhat higher than a stock one.
      08-19-2015, 05:37 AM   #4
alladin cars
Drives: bmw f20
haha i just upgraded the wheels on that as it was the very standard ones,
however the front end is an m sport,
its the new bi xenon headlights so im sure the wiring will be different although the clip to the headlights go straight on but it still doesnt work, there is a guide on here for the bmw f30 but theres nothing for this 1 series, at first i was thinking of doing the 2 series front end but just stuck with this,
surely someone has done this upgrade on here before
      08-19-2015, 06:05 AM   #5
Weiman
Weiman's Avatar
Sweden
156
Drives: BMW 116i M-Sport -14
Xenon? You know the LCI has LEDs right? I'm sure the wiring and probably the software are quite different, good luck
      08-19-2015, 07:21 AM   #6
alladin cars
Drives: bmw f20
I think your right it must be led
Do u think I've just shot myself in the leg by getting this front end put on
Should I go to the stealership and some how get a picture of the clip that plugs into the headlight maybe the wires might need rearranging
      08-19-2015, 05:14 PM   #7
AusF20/F48
AusF20/F48's Avatar
You will have to get the 3 lighting modules recoded (one behind each light pack and the main lighting module to accept the Leds and Xenons. Once coded all will work
      08-20-2015, 03:58 AM   #8
dishy
Drives: M135i
I don't know about all this 2015 technology of coding, but I'd still be concerned with the pin outs, and be comparing the F20 to the F30.
Resale value would only be higher for someone willing to modify their car, or drive a modified car. What if you get into an accident? That's going to be great fun having the repair shop get parts for the wrong vehicle and then fitting the parts for the wrong vehicle. Anyone with this mindset would be deterred from buying the car and this then diminishes resale value.
      08-23-2015, 10:51 AM   #9
alladin cars
Drives: bmw f20
Right I got them working changed a few wires from the FRM coded it job done
And in terms of selling the car don't think I'd be doing that anytime soon, this one may just be a keeper, my insurance covers it all
Now I'm thinking of opening the old headlights and fitting the angel rings in them
      08-23-2015, 02:01 PM   #10
max2005b
Drives: F20
There are some people in this forum that have successfully converted their old f20 to the new ones. Ask them about lighting. Worst case scenario you can bypass the lighting mechanism and relay the switch on lights signal to an external xenon/led system.
      08-23-2015, 02:27 PM   #11
I think this is the first rebuild to F20 LCI front. The others have rebuilt with the 2 series front.
      08-24-2015, 04:55 AM   #12
matthewcornish
matthewcornish's Avatar
Drives: M135i
Putting an M135i LCI front on my F21 M135i is on my to-do list...
Nice at last to see someone else doing so! I don't like the 2 series front so much...
Current: 2014 F21 M135i Estoril Blue
Previously: 2012 F21 116D M Sport Estoril Blue
      08-25-2015, 12:44 AM   #13
hardlix
Drives: 116i
A guy had upgraded his X5 to LCI and in order to make the LED light work properly, he had replaced the Footwell Module and did coding.
      04-16-2016, 01:07 PM   #14
aasimshahs
Drives: 118d f20
How much did this conversion cost you?
Where can i source the headlamp and frm and the bumper?
Could we see more pictures?
      07-28-2016, 02:13 PM   #15
saquibmiah
Drives: e90
front conversion
hiya car lookingf great
can i ask whatcoding function you changed and how you worked out where to move the pins on the harness
      08-06-2016, 11:52 PM   #16
Kiwi
New Zealand
145
Sorry don't like the new front bumper area were the park lights are.
2015 220i M Sport convertible.
2016 225xe M Sport.
      08-16-2016, 06:03 AM   #17
minijet
minijet's Avatar
Drives: Train
Hi everyone
116d auto
Ive done the conversion too.
the issue you have is that the wires connecting to the light assembly is upside down. play round with the combinations and it will work. its not coding related.
      08-17-2016, 07:45 AM   #18
P1 PET
P1 PET's Avatar
396
Drives: BOX ON WHEELS
I quite like the rear lights of the new 1 Series. They look so cool in person.
      07-16-2017, 04:36 AM   #19
saquibmiah
Drives: e90
hiya guy i finally done the front lci conversion can get the dam lights working have been playing around with the wires but nothing working do i have to code first before it starts working
      10-02-2017, 02:23 PM   #20
pjn11
Drives: BMW
Does anybody have the wiring diagrams on this as I have all the stuff but can’t get them to work?
      11-17-2017, 05:27 AM   #21
44nas
Drives: 435i m performance
hi im having a very hard time with this facelift conversion ive physically done the conversion, but no coding or rewiring, i can have get it coded but no one seems to know how to rewire, can you please throw some light on how you did it? or please inbox me with a number
      04-25-2018, 04:52 AM   #22
Duffiacz
Drives: BMW F21 120d 2013 remapped
Hi,
anyone knows what should you do with the frm wires as alladin mentioned ?
