01-08-2019, 01:29 AM | #1 |
Rep 6
12V under closed car
Hi
My car has no anti-theft and I would like to insert a blinking LED to make it look like there is an alarm. to do this I need to find 12v that are present only when the car is closed with the remote control and remain in this state until it is opened again with the remote control. is there any way to find this 12v? My car has no accessories, no Central Information Display thanks besth regards |
01-08-2019, 07:25 AM | #2 |
Rep 250
if your car has no accessories then its good news because nobody will steal it or parts from it,if you are worried about people breaking inside to hopefully find goods you left inside then i advise getting tints on all the windows and yes i know that under EU law the front windows must have a vlt of 70% window+tint but there are many tints that companies that produce tint light tints.
get the windows tinted,it will not only keep burglars away (no its not like an impenetrable wall but it is harder to snatch things from inside a car if it has tint applied on the windows) but it willl also help reduce the heat and make your car look nicer .Dont forget to go for good quality tint and i recommend getting atleast a metallized film installed
Bmw 114d
Honda Jazz Daewoo Matiz Daewoo Nubira II |
01-08-2019, 01:36 PM | #4 | ||
Rep 1,353
Just as a side note, are you reasonably sure it will work at all (aren't shy thieves an extinct species)? By the way, security systems that silently send an alarm signal to the owner or intruder handling specialists don't indicate that (to let the visitor stay for the appointment ) - lacking the indicator does not really prove the car is not protected (the true "clients" aren't expected to know that though ). Quote:
So it has the best theft protection, actually. "Knowledge only increases sorrow". |
01-08-2019, 02:00 PM | #5 | ||
Rep 1,353
Why? Dark colours accumulate heat as everybody should know from school physics/optics basics. "Solar control glass is not necessarily coloured or mirrored glass." Not necessarily: only by concealing your face, perhaps. |
01-10-2019, 02:52 AM | #6 | |
Rep 6
I do not have the extended ceiling light, but the base one |
01-10-2019, 06:12 AM | #7 | |
Rep 1,353
01-10-2019, 08:32 AM | #8 | |
Rep 6
https://www.newtis.info/tisv2/a/en/f...ystem/FpcQ82al A21 -> Roof function centre https://www.newtis.info/tisv2/a/en/f...sha/1VnXlbFqeM https://www.newtis.info/tisv2/a/en/f...n-sha/GFoyuoye I'm not sure it can be fitted I have to study |
01-11-2019, 06:01 AM | #9 | |
Rep 6
is mandatory to add "roof function center" impossible for my car there is the carpet at that point !!! |
01-11-2019, 07:59 PM | #10 | |
Rep 1,353
01-14-2019, 01:24 AM | #11 | |
Rep 6
for that I just wanted to put a bollard thanks again |
