BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > 116i (F21) Door dent replacement
      02-28-2016, 05:23 PM   #1
MrBriggsy
Drives: BMW F21 116i M Sport
Hi Guys,
So I recently bought a 116i F21 M Sport (2 weeks ago), and some muppet backed up into it 2 days ago, hitting the driver side door
The person that hit it is a family member, so trying to sort it out cash in hand. Went to BMW who gave me this amazing (not) quote:
Repair details :-
To Strip Vehicle And Renew
R/F Door (Removed)
Add/Time For Main Work
Strip + Retrim For Painting Of The R/F Wing
Includes: R + R Wheelhouse Cover And Badge
Does Not Include: R + R Headlamp
Strip And Refit Work R/R Side Panel Painting
Includes: Wheel House Cover R + R Not Included: Bumper Trim
And Fuel Filler Neck R + R
Preparation Time For Cavity Protection
Includes: Setting-Up Of Spray Gun
R/F Door After Treatment (Composite Work)
Remove And Refit/Renew (Check New Parts List)
Front Bumper Cover
Right Headlamp
Right Front Door
Adjust R/F Door
Rear Bumper Trim Includes: Rear Lamps Remove And Refit
Filler Neck Pot
Specialist Pre System Sweep
Specialist Post System Sweep
Check R/F Window Regulator
Check Wash And Vac
Check And Quality Control
Check And Road Test
Prepare And Paint
Preparation For Pre-Painting
Right Front Door New Part Painting
O/S/F DR Handle Cap Repair Painting <50%
Detailed Mask Detailed Mask
Blend In
R/F Wing Surface Paint
R/F Outer Handle Surface Paint Plast.
R/Roof Frame Surface Paint
R/R Side Panel Surface Paint
Rebuild Vehicle Fitting New Parts Listed
Labour Value £865.00
Paint and Materials £408.80
Specialist/Other Charges £21.00
E.P.A. Charge Specialist 10.00
Car Care Kit Specialist 6.00
Anti Corrosion Protection 5.00
New Parts :- £405.58
Right Front Door [1482] 272.74
R/LWR Door Seal [1514] 31.05
R/F Door Lock Cover [1574] 14.60
R/F Inn Channel Seal [1620] 58.56
R/F Door Insulation [1714] 20.68
Sundries 7.95
End of New Parts
_______
Sub-Total £1700.38
VAT £340.08
_______
Estimate Total £2040.46
£2040.46 is a bit excessive is it not...? Considering its a dent about 1 foot long and 1 inch deep. Anyway, managed to find a flood damaged 118d, same colour same spec's door for £200. How much can I expect for fitting of this? They need to move interior trim, window, door locks etc and the wing mirror.
Cheers
