04-11-2014, 10:05 AM | #1 |
Rep 4,822
Springs for M135i with adaptive damper
Hi all, I've been meaning to do something about the excessive rolling and squat on my M135i. I have read a few threads where the change of springs appear to have helped this, however I have only come across one person who have changed his springs on a car with adaptive damper. This person had used the same Eibach Pro springs for non adaptive damper, but Eibach doesn't recommend this.
I would like to know what other options I have and if anyone else has done this. Thanks. |
04-11-2014, 10:21 AM | #2 |
Rep 3,290
The best solution is to install a complete kit with matched springs and dampers, like a coilover kit. Bilstein and KW have good reputation, but I don't know if they offer kits for your car.
04-11-2014, 10:43 AM | #3 |
Rep 4,822
I agree. Had I not specced adaptive suspension from the factory, that's what I would have done. I've had great experiences with KW competition coilovers, H&R and Bilstein in the past on various cars, but because of my spec, I don't want to mess with the electronics (plus the fact that I've paid for the adaptive function!).
04-11-2014, 01:20 PM | #4 |
Rep 1,349
Drives: BMW F80 M3
I have H&R on my adaptive dampers. No issue at all.
04-11-2014, 02:51 PM | #5 |
Rep 4,515
I have h&r springs with adaptive and no issues
Current '22 X3M LCI.. |
04-12-2014, 04:16 AM | #7 |
Rep 4,515
Sport springs on mine with a drop of -25mm all round
Not the super sport springs, much harder and more drop
04-12-2014, 03:54 PM | #9 |
Rep 4,515
H&R drop means car sits level. Other products like ACS and Eibacha give a nose down stance.
I have thicker ARB's all round and quaife LSD. Ride in comfort is now more like how it was in sport with oem springs. Even in comfort, corners flat and rear is much better controlled over uneven, poor surfaces. Traction is much improved, TC light flashing is almost non existent. Sport mode, ride is firmer but still OK. I think my car is how it should come from the factory, hence why BMW have stiffened up m235i all round and will hopefully be offering an LSD as a retrofit.
04-13-2014, 03:46 PM | #11 |
Rep 1,349
Drives: BMW F80 M3
Also have the sport h&r 25mm drop. Comfort still comfy and sport not too hard. I like the ride much better now.
04-13-2014, 05:59 PM | #12 | |
Rep 43
How much did it cost for the ARB's?
Do you have a link to them? Did you have the suspension done too or just the ARB's? Thanks Quote:
04-14-2014, 06:12 PM | #13 |
Rep 4,515
ARB price see link below from Birds here in the UK.
http://www.birdsauto.com/parts/M2031215350 I believe eibach do ARB kits too. Yes, ARB, LSD and springs all fitted in a oner Car is much more chuck able in the bends but ride is still v good.
04-14-2014, 07:24 PM | #14 | |
Rep 43
I'll have a look into it. What would you get first? The ARB's, the H&R Sports Springs or the LSD? Last edited by lac.le; 04-14-2014 at 10:44 PM.. |
04-15-2014, 02:59 AM | #15 | |
Rep 4,515
If you want looks and improved handling - springs only. If you want stealth handling and traction improvement then arb's and LSD. I wanted all of the above hence why I did the lot. |
04-15-2014, 03:14 AM | #16 |
Rep 3,290
Good handling depends on the driver and conditions. A rally car does not have the same setup in every rally, and two drivers on similar car could prefer very different setups. Notice that stiffer springs, lower ride height or stiffer swaybars could also make the car slower or more difficult to drive in some conditions.
The LSD has no drawbacks in my opinion. In general, the smoother and flatter roads you drive on, the lower and stiffer suspension is suitable. For bumpy roller coaster B roads, you want lots of suspension travel and a rather soft setup. A smooth driver can also get away with a softer setup than an edgy driver. Contrary to what many people think, the soft setup will give you more grip and traction, as the load is more evenly distributed on the tyres. The same thing goes for tyre pressures. By driving smoother, you can reduce the tyre pressures a bit, and gain grip. |
04-15-2014, 04:01 AM | #18 |
Rep 3,290
I haven't tested Eibach/H&R for the M135i, but H&R road springs are usually firmer than Eibach road springs. While H&R are more focused on performance, Eibach are more focused on comfort.
04-15-2014, 05:39 PM | #19 |
Rep 4,515
Lots of bumpy poorly surfaced roads here in the UK and having driven m135i before and after, I can vouch that shorter springs sort out the much publicised oem flaw of too much understeer at front and rear gets ragged not even near the limit.
04-15-2014, 08:23 PM | #20 | |
Rep 43
