BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Prodrive GC-012L on M135i
      11-16-2013, 11:21 PM   #1
madvlam
madvlam's Avatar
Hong Kong
Drives: Mineral Gray M135i
Rims are Prodrive GC-012L with Michelin PSS: 225/35R19ET44 (19x8.5) front and 255/30R19ET51 (19x9) rear, sills with M Performance stickers, not very standout but feel just right, ride height seems a bit too high after wheel change for unknown reason (on paper should be almost identical to OE)
More can be found on flickr: http://www.flickr.com/photos/2141956...7637750058326/
2001: Pegueot 206GTi
2009: VW Golf GTI MK6
2013: BMW ///M135i
      11-17-2013, 01:06 AM   #2
madvlam
madvlam's Avatar
Hong Kong
FYI: if you are interested in the unsprung mass reduction, it is about 6lb (2.7kg) per wheel - for instance rear wheel + tyre from 52lb down to 46lb.
2013: BMW ///M135i
      11-17-2013, 02:20 AM   #3
1bmwJ
Drives: M135i
Looks good! Is the ET and offset enough to be flushed with the fenders?
      11-17-2013, 02:22 AM   #4
madvlam
madvlam's Avatar
Hong Kong
The offset is almost exactly the same as OE (47F/52R) so I don't think so
2013: BMW ///M135i
      11-17-2013, 04:28 AM   #5
aus135i
aus135i's Avatar
Drives: F80 M3
i like it!
GONE: E82,E83,K46,1199s,RS250,F20,F25,F82,Cayenne,G83
NOW: G07, G20, K66
      11-17-2013, 05:23 AM   #6
Vervain
Drives: .
      11-17-2013, 05:26 AM   #7
vladberca
vladberca's Avatar
Romania
763
You should lower it a little bit
      11-18-2013, 08:14 AM   #8
madvlam
madvlam's Avatar
Hong Kong
Indeed... btw anyone has experience with M Performance Chassis? (Claimed to stiffen a bit plus lower another 10mm compare to Non-adaptive M Sport Suspension)
2013: BMW ///M135i
      11-23-2013, 05:47 PM   #9
EdM5
EdM5's Avatar
Netherlands
4066
Drives: G26 i4 M50 & E70 X5 Xdrive35d
Looking good!
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d
      11-24-2013, 04:33 AM   #10
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Offset might be similar but your new wheels are wider so they will stick out more by 14mm front and 13mm rear
There are also options of lowering with Eibach or H&R springs with using exsisting dampers and also option with coilovers like KW or Bilstein
2018 BMW E87 M2
      11-24-2013, 06:51 PM   #11
madvlam
madvlam's Avatar
Hong Kong
The rear is more noticeable but can't tell about the front. Yet both are still not stretched beyond the widest point of the wheel arch...
2013: BMW ///M135i
      11-25-2013, 05:12 AM   #12
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Looking at sizes available for this wheel below
http://www.prodrive-japan.com/produc...012l/size.html
I think you may have the 8.0 ET45 front wheel as 8.5" ET47 doesn't seem to be available?
Maybe that's why it doesn't look as far out as they only stick out more by 6mm front if that's the case
2018 BMW E87 M2
      11-25-2013, 05:54 AM   #13
madvlam
madvlam's Avatar
Hong Kong
Sorry my mistake, yeah it's 19x8...
2013: BMW ///M135i
