BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > M Performance tips on stock M135i exhaust
      02-25-2015, 04:02 AM   #1
BWT
Drives: M3
Will the M Performance exhaust tip fit onto the stock M135i exhaust? Also, any info on how to attach it would be appreciated.
I am happy with the sound of the stock exhaust but just want slightly larger tips.
Thanks in advance.
      02-25-2015, 03:36 PM   #2
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Standard tailpipes diameter is 60mm and MPE is 67mm.
MPE tips slide on and are secured by a grub screw at the 6 o clock position.
To fit them onto smaller tailpipes you need a 3mm thk packer sleeve with a wide split along its length. Slide sleeve over tailpipe and position slot pointing downwards. Slide on MPE trim so sleeve keeps it concentric and tighten grub screw to secure.
      02-27-2015, 04:54 PM   #3
BWT
Drives: M3
Thanks for your response.
Do you know how to remove the original tip from the OEM exhaust?
      02-27-2015, 05:40 PM   #4
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Oem tips are held in place using friction. Use a block of wood and a mallet to knock them off the exhaust pipes
      02-27-2015, 07:09 PM   #5
BWT
Drives: M3
