BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > boot creaking solutions?
      07-09-2017, 07:27 AM   #1
luger08
Drives: BMW F20 116d
Hi F20 drivers,
I have problem with creaking noises coming somewhere from boot area, in normal driving it's ok but when chassis is flexing constantly makes krr krkkr noise and it's pretty loud.
is there any solution?
      07-09-2017, 08:27 AM   #2
eray
Turkey
20
Drives: 2014 Audi S3 Quattro 300 Hp
get your trunk lid checked in the first place.
it's a common problem on c segment cars.
it could be your cargo cover too.
other problem could be your back seats. if you have folding rear seats you can apply some lubricant on their locking points / panel that they rest.
      07-10-2017, 02:14 AM   #3
DoggieHowser
Drives: F87 Pure F20 125i MSport 2017
Pretty much every hatchback develops some flex in the rear boot at some point I imagine. It's just due to the rigidity of the car.
That said I've heard some rattling that is caused by improper seating of the boot cover.
      07-16-2017, 02:03 PM   #4
luger08
Tried lubricating latches, seat covers checked, empty boot etc...
it comes only from passenger side, something is flexing
      07-26-2017, 12:27 AM   #5
Fidiman
Fidiman's Avatar
France
113
Drives: BMW 120d e82 M Sportpaket
2010 120d E82  [10.00]
Have the same issue. Problem wasn't here when I collected the car and now it drive me nuts. Sometimes, I feel driving in a cheapy hatchback
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ...
French community of 1 and 2 Series: One-Two-Bimmers
      07-26-2017, 09:54 PM   #6
No one
Drives: F21 118i
Rip off the boot lid and make it a glorious pickup.
      10-16-2017, 04:51 PM   #7
luger08
tried to solve the problem but no luck
checked boot lid closure and gaps and looks fine to me
rear seat latches taped but sound is still there
put the car on the lift to inspect suspension and all seems fine
the sound can be heared when car is going uphill or downhill when chassis is flexing lik kriiik kriiik sound and sometimes for no reason over bumpy roads or small brake pedal press
really annoying
      10-16-2017, 05:52 PM   #8
emil111
emil111's Avatar
Romania
44
Drives: BMW 114d
have you considered removing the boot shelf and putting it back again?
one of my window seals kriiik kriiiked or atleast made a similar sound until ive had it replaced,try inspecting the seals of the boot/back half of the car.
(the seal creaks happened on bumpy roads or when escalating hills and going down slopes but only at the beginning.....they did not make any sounds when braking though....ofc expect when i was breaking on bumpy roads then yes they did make a sound)
Bmw 114d
Honda Jazz
Daewoo Matiz
Daewoo Nubira II
      10-20-2017, 01:30 PM   #9
luger08
door seals are my second problem, driver one squeaks alot and stops when I drop a window a bit.
Today I drove the car with boot open and sound is still there, so its the suspension related or brakes I dont know.
It's loud pretty much and happens mostly after the braking or sometimes over bumps.
recently I addes Eibachs on my car and visually rear suspension is like brand new?
      10-20-2017, 03:54 PM   #10
emil111
emil111's Avatar
Romania
44
Drives: BMW 114d
mister luger i have made a topic about the window seal creak
http://f20.1addicts.com/forums/showthread.php?t=1413231
i have had this problem myself and sadly there was not much else i could do besides changing the window seal....mine did look gasly....you can try the solutions given to me by the other members...they might work...and if not then the last solution would be changing the seal
Bmw 114d
Honda Jazz
Daewoo Matiz
Daewoo Nubira II
      11-22-2017, 09:36 PM   #11
oliverpool
Drives: 116D
Apply this on the seals
https://www.amazon.com/Chemours-D124.../dp/B073Y4557Y
It work wonders
      11-28-2017, 10:29 AM   #12
V-Eight
V-Eight's Avatar
792
Drives: MY22 M3 G80 Comp.Xdrive
Have the same issue in mine, but behind the left rear seat. i think is something flexing between the trunk and the rear window. I've dismounted everything, running the car without plastics, covers, moquettes etc. The crack is still there, but honestly, now I don't mind it anymore.
      12-12-2017, 02:17 PM   #13
G2G
Sold: E46 330CI, E90 320dA with 270000km
G2G's Avatar
Austria
Drives: 1M
2015 BMW 118d  [0.00]
2011 BMW 1M  [10.00]
Boot Cracking
I have got exactly the same problem on my F20!
I have had it checked several times by BMW, once it was gone after my dealership applied lubricate on the door seals - it was gone, but came back after around a 1000km.
It really sounds and feels like the whole trunk part is nothing while driving on a bumpy road!
Has anybody of you found a solution to this?
