BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Bmw f21 water pssenger side problem
      04-24-2016, 10:58 AM   #1
r0b3r
Drives: Bmw F
hello, I have a problem in my bmw f21, today dismounting to install pdc front, I have met with the passenger side carpet full of water, someone can help me? not where it enters the water.
      04-24-2016, 01:02 PM   #2
neilwilliams
Drives: F20 116iSE
I had this on a different car some years avo. It was caused by a blocked drainage channel which had caused a backlog of rainwater and might have filled an air filter as well.
      04-24-2016, 04:00 PM   #3
r0b3r
Drives: Bmw F
Someone may take me a help? it can not be happening, is very rare.
      04-25-2016, 08:29 AM   #4
No one
Drives: F21 118i
Smile "The rain in Spain stays mainly in the plain."
http://f20.1addicts.com/forums/showthread.php?t=1176995
"Give piece a chance": contact your dealer. It shouldn't be expensive to fix (if not just free).
      04-25-2016, 09:29 AM   #5
r0b3r
Drives: Bmw F
Thanks, but I want to fix it myself, I have to do? my car is September 2014, and this wet passenger side (right) front, the bottom of the carpet.
      04-25-2016, 11:31 AM   #6
r0b3r
Drives: Bmw F
it can also be ac clogged drain? someone can guide me to review all drains and grids replacement seen in previous post? I do not know where it is
      04-25-2016, 12:32 PM   #7
No one
Drives: F21 118i
Well, I watched the mechanic do it but I can barely remember details. The two points I noticed:
1. he used some access from under the car (started under the hood, like unlocked those, dived underneath to remove(?) and that was it);
2. it was really fast - just a few (a couple of?) minutes.
These things are located near/under the front (windscreen) pillars. It's hard to locate them on a diagram, especially as I don't know how they look (like this? they must be some net filters I guess), but this one might be helpful/indicating: Various grommets / covers (refine the diagram selection for your car but it must be exactly the same I would guess).
A textual description: Anybody got info on the grommet recall??.
      04-25-2016, 02:42 PM   #8
r0b3r
Drives: Bmw F
my car is September 2014, does not have those things, you have free hole. what else can look? You can have some clogged drain? where are desagues? I also made a diagnosis and mark me auc sensor error, I do not think it has anything to do?
      04-25-2016, 04:14 PM   #9
No one
Drives: F21 118i
If you happen to have a sunroof you might be experiencing an issue similar to this.
      04-25-2016, 08:29 PM   #10
r0b3r
Drives: Bmw F
No sunroof
      04-26-2016, 07:35 AM   #11
r0b3r
Drives: Bmw F
I am not able to find the fault where it enters the water. also I have another problem, is heard a clang off when I start walking.
      04-26-2016, 10:45 AM   #12
No one
Drives: F21 118i
"At least you tried."
"You can't leave... Without saying "good night"." I don't know what exactly you refer to but I guess I heard something of the kind. I never worry: the car "lives on it's own".
Do you really have to hate BMW service that much? With a warranty car you should have your concerns ready for them.
      04-26-2016, 12:55 PM   #13
r0b3r
Drives: Bmw F
bmw given date two months of delay to bring car to check, I'd rather fix it. you know how to fix the clank when leaving up? It sounds very ugly
      04-26-2016, 09:57 PM   #14
No one
Drives: F21 118i
My wild guess is a (single) clanking sound I sometimes hear from under the hood when leaving the car can be related to hot turbine (the heat shield?) cooling down. I usually drive moderately before a stop and this could be why it's an infrequent case.
      04-27-2016, 02:46 AM   #15
r0b3r
Drives: Bmw F
I have already found noise at startup, it is an RDC sensor I loose inside the rim
Water todabia found no solution.
      05-04-2016, 01:35 PM   #16
r0b3r
Drives: Bmw F
I've been hose water and do not detect water ingress, I suspect clogged drain air conditioning, someone knows where?
      05-21-2016, 04:55 AM   #17
r0b3r
Drives: Bmw F
drain ac is http://www.subirimagenes.com/imageda.../958843612.jpg circle red ?
      05-21-2016, 10:08 AM   #18
No one
Drives: F21 118i
http://www.realoem.com/bmw/enUS/show...78#64119207092
      05-21-2016, 10:19 AM   #19
r0b3r
Drives: Bmw F
yes, but it is not connected there
      05-25-2016, 03:21 AM   #20
r0b3r
Drives: Bmw F
takes three days, bmw car and still unlocated again nothing ....
      05-28-2016, 04:20 AM   #21
r0b3r
Drives: Bmw F
I have already returned the car, they say they have unclog the drain tube AC, but the car remains the same .... is still wet carpet ...
      06-16-2016, 01:42 PM   #22
r0b3r
Drives: Bmw F
Hello, after several months, still have the problem, I put fogger and no smoke is seen outside the passenger compartment, carpet is still wet, now it makes more heat on the street and carpet is dry, but the problem remains and no what else to try and do things.
