BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > looking for volks te 37
      06-11-2014, 06:48 AM   #1
Gorro47
Drives: BMW 125d, FocusRs17,E39m5, etc
Hi guys like the title says , i´m looking for someone with the volks te 37 wheels on a f20/f21.
Thinking on ordering them but wanted to ask for feedback first, rubbing issues and stuff.
thanks for your time and help.
      06-12-2014, 07:49 AM   #2
GeoBem007
Belgium
Drives: F21 M135i
What are the sizes you're looking at?
I beleive they only have sizes available for E87/E88 and those are no issue on F20/F21 as there is slightly more space.
Also, I haven't seen anyone with TE37 on a F20/F21. Unfortunately, they're not as concave as I wish they would be
      06-13-2014, 12:20 AM   #3
bbenny
Drives: M2
The current TE37 SL is only made in 18" to fit BMW (5x120PCD) with the following sizes
18x8.5 +35 - Might fit but may need front guard modification
18x9.5 +22
18x10.5 +20
18x11 +18
The other sizes are no chance on the F20
These are from the Rays (Volk) japan site
      06-13-2014, 02:53 AM   #4
Gorro47
thanks for the info bbenny.
So the ones that maybe will fit without problems , will be 18x8.5 +35 front - 18x9.5 +22 back?
      06-13-2014, 03:41 AM   #5
bbenny
Drives: M2
no you wont fit the 9.5" rear offset is too aggressive so it would stick way out from the guards.
Even the fronts with 8.5 +35 will be very close to the guard and may rub depending on tyre size.
You would have to run 8.5 +35 front and rear.
      06-13-2014, 04:43 AM   #6
Gorro47
i understand 1 series is the cheap one, so making expensive wheels for it can be a bit of a risk, hope they make it
      06-13-2014, 06:46 AM   #7
bbenny
Drives: M2
Yeah the biggest let down with the F20/21 is the offset, they are so high that we cant get the regular sizes or more concave wheels that other models get.
      06-13-2014, 07:00 AM   #8
That is one way of seeing it. Another way is to say that it has a rather wide stance from the factory. Even quite modest wheels are rather flush compared to other models.
      06-13-2014, 05:51 PM   #9
bbenny
Drives: M2
It does have a wide stance, but it could have the same stance just with a lower offset wheel. I don't know if higher offsets create better handling or performance. look at the M3/M4/M5/M6 These are high performance cars that have very low offsets. (and incredible wheel choices because of it
      06-13-2014, 10:39 PM   #10
They look good with expensive aftermarket wheels indeed. But if you equip them with affordable normal offset wheels, they are far from flush. I see this a lot at winter time, when they are running narrower tyres.
      06-15-2014, 05:32 AM   #11
GeoBem007
Belgium
Drives: F21 M135i
Here's the only one in 1-series sizes..
http://www.rayswheels.co.jp/products...heel=TE37TTAPM
18 8J FACE1 S L 45 5 120 φ72.6HC BMW 1er
18 9J FACE2 S S 50 5 120 φ72.6HC BMW 1er Rr.
      06-15-2014, 09:07 AM   #12
Gorro47
Such a nice wheel, thought to see at least one person with it.
thk´s for the info.
      06-17-2014, 02:47 AM   #13
GeoBem007
Belgium
Drives: F21 M135i
thk´s for the info.
Very nice indeed, but very expensive. And not available in a nice concave look for our 1-series. Otherwise I would've bought a set
