BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Replacement rotors for F20 118i
      06-08-2014, 11:48 PM   #1
lefthander
Drives: BMW F30
Anyone changed their front/rear rotors to slotted or cross drilled?
Thank you.
      06-17-2014, 03:06 AM   #2
AusF20/F48
AusF20/F48's Avatar
Not yet, but that will be what I want to do when my M front brakes need replacing
      06-17-2014, 12:47 PM   #3
lefthander
Drives: BMW F30
Your m front brake is m sport or m performance? M sport or M performance replacement should be easier to find compare to oem 118i size.
      06-19-2014, 02:26 AM   #4
AusF20/F48
AusF20/F48's Avatar
I am surprised by the lack of comments to this thread
I was hoping that someone would have already done this upgrade and could pass on some advice about where to get the rotors.
Are the M performance (option) the same as the 330i rotors?
      06-19-2014, 02:32 AM   #5
Madgambler
Madgambler's Avatar
Have changed the front rotors but not the rears yet.
http://f20.1addicts.com/forums/showthread.php?t=951685
Madgambler
325i (E30) => Alpina B3.33 (E46) => Alpina B3s (E46) => 130i M Sport (E87) => Cayman S (987c) => Carrera S (997) => M135i (F21)
      06-19-2014, 02:58 AM   #6
I am not so sure that it is an upgrade to use slotted or cross drilled rotors.
      06-19-2014, 04:55 AM   #7
ttimbo
ttimbo's Avatar
282
I think you'd want to be very certain about the quality of any replacement rotors that are slotted, or cross-drilled. I've seen some cracked slotted or drilled rotors at track days, which makes me very wary of them. As Ove notes, they're not necessary.
Peugeot T9 308 GTi 270
      06-19-2014, 05:43 AM   #8
I think BMW has some dimpled ones as an option in the parts catalog.
      06-19-2014, 05:57 AM   #9
AusF20/F48
AusF20/F48's Avatar
I gather that the fronts on your M135i are the same as the M Performance (option)
Did you buy genuine or aftermarket?
      06-19-2014, 06:00 AM   #10
AusF20/F48
AusF20/F48's Avatar
Hence the questions
I am not a fan of Aftermarket products.
I would prefer factory or a recommended reputable brand
      06-19-2014, 06:06 AM   #11
AusF20/F48
AusF20/F48's Avatar
I agree with you that the term 'upgrade' was probably the wrong choice of words.
For normal driving habits there is little advantage (apart from looks)
Though there are some advantages with having engineered rotors that I do appreciate
      06-19-2014, 06:21 AM   #12
AusF20/F48
AusF20/F48's Avatar
The best discs I have found are grooved and vented (used on previous cars)
Has anyone had any experience with Dimpled and grooved?
      06-19-2014, 06:41 AM   #13
Madgambler
Madgambler's Avatar
Mine are genuine M Performance rotors as fitted by my local main dealer and they are dimpled and grooved. They were a special order from Germany though as not stocked as standard in the UK.
Madgambler
      06-19-2014, 08:49 AM   #14
lefthander
Drives: BMW F30
Think all of us deviated. I just want to know if there's option for F20 118i stock brake caliper?
      06-19-2014, 09:01 AM   #15
Not from BMW, as far as I can see.
      06-20-2014, 01:53 AM   #16
AusF20/F48
AusF20/F48's Avatar
Thank you.
Sorry, I was under the impression that you wanted slotted or cross drilled rotors to replace your existing standard rotors.
If so, there are 'aftermarket' available (Ebay) and some engineering shops can groove (mill) your standard rotor.
