05-25-2015, 12:49 AM | #1 |
Rep 417
F20 LCI Steering wheel
Hey guys,
I've got a 07/13 build F20 125i with the M-sport pack and I've always wanted the M-sport steering wheel that the new LCI models have as I think the steering wheel in my car looks fat and ghastly. If I order the new steering wheel is it plug & play or does the car need to be re-programmed? I can't find any solid information about this. http://www.realoem.com/bmw/enUS/show...diagId=32_2182 Hope someone can help! Thanks
F82 M4 | 6-speed manual | PP performance Stage 2 tune | Re-valved Bilstein B16s | VRSF midpipe | OEM CS front splitter | OEM GTS hood | OEM M-performance rear diffuser| Evolve tuning catless downpipes | 310rwkw (415rwhp)
05-25-2015, 01:27 AM | #2 |
Rep 1,233
If the controls operations have not changed and from what I can see the connections look the same, it should swap.
The only issue is the airbag, it may have to be coded in. If you are going to buy the wheel though your dealer, get a quote from them for the supply and swap over. That way it is covered by warrantee. |
05-25-2015, 10:26 PM | #4 |
Rep 417
Ah thanks I had a feeling it was, but wasn't sure of the particulars.
Thanks for the info.
05-26-2015, 03:51 AM | #5 |
Rep 4,512
I did this swap on my sept 2013 m135i. Provided you disconnect the battery, there's no coding etc required.
In addition to the correct airbag, you will also need the correct button set for the new wheel as existing MFSW buttons aren't the same shape so won't fit. Here's mine with m3/4 paddles and trim. Last edited by Bee Pee; 05-26-2015 at 08:34 AM.. |
05-27-2015, 12:57 AM | #6 |
Rep 417
05-27-2015, 08:49 AM | #8 |
#12
516
Rep 475
Drives: Alpina B3 G21 Touring
You can have my steering wheel next month, if we can agree on a fair price. I am opting for the Performance steering wheel in a couple of weeks.
Problem is: you will still need the airbag and some of the buttons. But as far as I know, it is not allowed to ship airbags by post so it would be the best to buy that from your local BMW dealer.
2022 G21 Alpina B3 - DG/COGNAC - 8ZF
2019 F82 M4 S55 ZCP - SO/CLOTH - DCT (Sold) 2017 F87 M2 N55 - LBB/LCNL - 6MT (Sold) 2005 E46 M3 S54 - TS/GN5TT - 6MT |
