BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > m135i spark plugs to 116i
      07-28-2015, 03:14 AM   #1
badsay
Drives: 1.16i M Sport
hi again. i remapped my ecu to 200hp 310nm in our forum they are changing the plugs with m135i plugs. today i went to dealer and noticed the 135i plugs little taller than standard 116i plugs. is there any problem with it ? can i use it ?
      07-28-2015, 03:32 AM   #2
ngbernie
Drives: F30
Any issues using back the stock ones for tuned engines? I'm not sure if there is any improvements.
You did the ECU tune? I remember you mentioned about failed engines after tuning, did they isolate the faults or directly link it to the tune?
      07-28-2015, 03:46 AM   #3
badsay
i make a soft tune the failed engines are 220+ hp
the stock one dies quickly they say. they're using 135i plugs but im worried about its size
      07-28-2015, 07:09 AM   #4
badsay
photos added.
      07-28-2015, 02:43 PM   #5
selçukdal
selçukdal's Avatar
Drives: Bmw M4 Maserati GT MC Huracan
you can use it bro dont worry as i said today
      07-30-2015, 10:19 PM   #6
AusF20/F48
AusF20/F48's Avatar
The only issue is the clearance in the head to top of the piston.
If the clearance is OK and the plugs are the same gap it should be OK
      06-08-2022, 12:14 PM   #7
aazidane
Drives: BMW F30 316i 2014
Can i use ngk 97506 spark plugs at mhd stage 2?
      06-09-2022, 02:21 AM   #8
IJO
Drives: BMW 116I F20
Denso make Iridium plugs for the N13 1.6:
https://www.buycarparts.co.uk/denso/7744982
NGK version is ILZKBR7B8G 97968
I believe its a cooler running one.
I wouldn't risk plugs meant for a 135i.
      06-09-2022, 06:23 AM   #9
stupar
Drives: BMW F20
I am running MHD stage 1 tune on F20 116i also with N13 engine. I've had the MHD stage 1 tune with OEM plugs for 2 years, no problems at all. After that, I changed (they were getting old, not broken) plugs to OEM BOSCH (ZR5TPP33S) for M135i, not much of a difference really, but it can be considered as upgrade as far as the quality goes. For futureproofing, you can go with M135i plugs. There is a difference in size but they fit no problem what so ever. Hope it helps.
      09-06-2023, 11:46 PM   #10
Wellingtonz
Drives: bmw 118i f20 n13/ 320i F30 N20
hi is it the original bmw ones made by champion? https://www.engsoon.com.sg/index.php?route=product/product&manufacturer_id=210&product_id=50025&sort= p.price&order=DESC&page=52 ?
