BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > possible to tune 118i to 120i?
      02-08-2017, 08:34 AM   #1
iamsen
Japan
Drives: 2024 X4 m40i
Greetings.
I've just bought a unicorn, the 2015 118i with the 1600cc N13 engine. As far as I can tell, it's identical to the 120i except that it's detuned. Would anyone know what/how it was detuned and how I might re-tune it?
Last edited by iamsen; 02-08-2017 at 08:38 AM.. Reason: thread is worthless without pics
      02-08-2017, 09:20 AM   #2
It is a matter of chip tuning. All N13 engines are good for around 220 hp.
iamsen1.00
      02-09-2017, 02:53 AM   #3
eray
Turkey
20
Drives: 2014 Audi S3 Quattro 300 Hp
the differences between those two variants of N13 are very minimal.
mechanically the 170-177ps one has heat exchanger for oil and a slightly different exhaust system.
other than those, it is the engine mapping. you can easily go for 220hp at stage 1 for both cars.
i heard some people swapping their intercooler with a bigger one after remapping, but i am not sure which size you need to eliminate lag.
iamsen1.00
      02-09-2017, 04:35 AM   #4
iamsen
Japan
Thanks, you two. I've been reading up on the chip thing, I guess I'll just go for a simple plug and play chip for a little bit more ponies.
      10-24-2017, 02:13 AM   #5
Ruldark
Ruldark's Avatar
Drives: F20 116i sport
I used AC piggyback with exhaust system got 215 hp.
If you can get a hand on 2nd hand it will be a lot cheaper
      09-04-2019, 06:27 AM   #6
smidling
Drives: BMW 116i F20
Help with tutorial
Hello, I own 2012 116i with N13 engine.
Would you be so kind to explain the process that you went trough to get additional power?
      09-05-2019, 06:07 PM   #7
DuarteG
Portugal
Drives: BMW 330e Hybrid
Greetings.
Venturatuning.pt developed a powerbox for that engine up 200Hp and 300NM
I bough them for my 2018 F30 330e, now 314Hp.
The only reason that I bought it was from reading a lot from others users in bimmerpost .
the main difference from others like Racechip and other generic producers is they actually do tuning in dynobank AND on road, they develop and built themselves the units, fiberglass, original plugs from OM brands.
Not cheap, I’ve payed 750€ but never had problems.
