01-08-2014, 05:19 PM | #1 |
Rep 897
Drives: F90 M5
Adaptive M Suspension - Can you feel the difference between Comfort and Sport?
I have the Adaptive M Suspension on my 125d and when I press the Sport button I can feel the steering get heavier and the throttle get sharper, but the suspension doesn't really feel any different. I would say it feels maybe 5% stiffer, if any.
Should there be a noticeable difference in ride quality / stiffness when this button is pressed (ie is mine broken)?
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
01-08-2014, 10:15 PM | #2 |
Rep 931
Yes, you should notice a difference but of course it is only changing the damping rates, not the springs and further as the damping is Adaptive is varies a bit with speed and conditions anyway. So sometimes you can switch back and forth and think there's little in it, whereas at other times the change is more marked.
I find the most obvious differences are with low speed primary ride control - so try a large speed hump at, say, 25km/h in Comfort and it feels almost disturbingly underdamped - floating at the top of its travel and having a two-phase soft bob as you come off the other side. The same bump in sport has it crest and settle much more sharply, without any float or bob. Otherwise, drive along a chopped up bit of road and switch and the ride should feel flatter and with a bit more harshness transmitted - like you added 10psi to the tyres.
John
17 F87 M2 Pure - long beach blue 10 E91 320d LCI - space grey - black dakota - steptronic - innovations - 157s - front PDC - Konis 99 BMW Baby Racer - red; 05 Renaultsport Clio 182 Cup - French Racing Blue - Konis - Eibachs - Remus - Turinis |
