BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Help with 8.5J and 9.5J alloy wheels
      12-30-2013, 09:40 AM   #1
Robhamilton
Drives: Bmw 118D sport
Hi I have 118D 5 door and was wondering if 8.5J front and 9.5J rear rims would fit and not rub any one got any experience or pictures ?
Thanks
      12-30-2013, 10:07 AM   #2
SixDegrees
SixDegrees's Avatar
Drives: M135i
2011 Abarth 500  [0.00]
Thanks
Seems quite wide. What size tyres were you planning on fitting and are you planning on lowering?
2014 [14] M135i, 3dr, MG, Auto, SP, CP, HS, HK and FBP
Recent Past.....
2011 [61] Abarth 500, Funk White, Leather, H&R
2007 [57] 320d M-Sport Touring
Pre 2007 - GT TDI 4MO, Mk4 R32, A3 TQ, A3T, Cupra R and on and on and on.....
      12-30-2013, 10:53 AM   #3
Robhamilton
Thanks
I was planning on lowering yes that's why I am Abit conscious of such wide wheels I hadn't decided on tyres yet, I think the safe option it to stick with 7.5 or 8J rims really
      12-30-2013, 01:02 PM   #4
Lowering does't really matter. It only limits the outer part of the suspension travel, while the risk of rubbing is highest at the inner part. The suspension can bottom out even when the car isn't lowered.
8.5" wheels should be no problem. More than 9" is probably more of a challenge.
      12-30-2013, 01:05 PM   #5
Robhamilton
Thanks a lot ! Really helped me out here
      12-30-2013, 01:48 PM   #6
SixDegrees
SixDegrees's Avatar
Drives: M135i
I disagree, lowering increases the risk of rubbing on wider rims/tyres, you can 'get away' with a certain increase in width without lowering, but lower it and then depending on off-set, strut and inner arch construction, etc you may end up rubbing..... been down this road before when car was too low, so had to opt for less of a drop to stop the rubbing (back in the day).
Anyways, as above, my pref would be to go for a 8.5" on the back, 8" up front.
Recent Past.....
      12-30-2013, 02:31 PM   #7
The suspension travel is the same down to the bumpstop even if the car is lowered or not. Some show cars change the bumpstops to limit suspension travel to allow huge wheels, but that is not supposed to be approved for road use. If you raise your car and drive very carefully, you will perhaps not notice that the wheels/tires can rub, but they sure can if it rubs when it is lowered.
      12-31-2013, 01:52 AM   #8
GeoBem007
Belgium
Drives: F21 M135i
Front 19x8.5ET40 with 225/35 and back 19x10ET50 with 255/30 fits. A very slight roll of the front arches might be necessary, but otherwise it fits like a charm. (19x)8.5ET45 is also widely available and should give enough clearance.
Same goes for 9.5ET45 in the back, with same tyres.
I fitted Falken FK-453's. Your choice of tyre will be important as well. Some brands are more square and might cause rubbing.
      12-31-2013, 04:03 AM   #9
Robhamilton
Thanks, I'm only running 17 inch alloys not 19 so logically that should reduce the risk or rub even more ?
      12-31-2013, 04:26 AM   #10
GeoBem007
Belgium
Drives: F21 M135i
Depends on your tyre size.
Logically, you'll try and get a similar diameter but as you will be running a higher tyre, you might be more square and thus might rub easier than with a (semi) stretched 19" tyre.
      12-31-2013, 01:01 PM   #11
SixDegrees
SixDegrees's Avatar
Drives: M135i
This might help.....
http://www.willtheyfit.com/
Recent Past.....
      12-31-2013, 03:05 PM   #12
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Pics of VMR v710 on M135i here (not my car)
18x8.5 ET45 with 3mm spacer front with 225/40/18
18x9.5 ET50 rear with 245/35/18
https://www.facebook.com/media/set/?...1&l=73ec35a1a1
2018 BMW E87 M2
      01-01-2014, 06:02 AM   #13
SixDegrees
SixDegrees's Avatar
Drives: M135i
They look a bit wide and bit stretched for my liking. Love the style though.
Recent Past.....
