BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > NBT EVO retrofit
      09-13-2015, 05:50 AM   #1
juniortabak
juniortabak's Avatar
47
Drives: M135i
NBT EVO retrofit
Hi,
Need help with NO Signal of GPS.
retrofit NBT EVO in F20 2015 LCI.
replace many GPS antennas but no Signal.
thanks
      09-14-2015, 04:41 PM   #2
LatinBimmer
Peru
133
Drives: X5 2014 Sparkling Brown
Hi, I'm considering in doing that retrofit too...
Did you flashed and code the NBT after installing? Are you using genuine FSC codes in order to get Navigation work? or just using Emulator?
      09-15-2015, 11:12 PM   #3
juniortabak
47
Drives: M135i
Hi,
yes we flashed and coded the units but we still have some GPS problem,
we don't have any GPS signal we don't no yet if its the OEM antenna or unit problem. but its work perfect and the unit is much faster then the NBT.
      09-17-2015, 08:43 AM   #4
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
When I took out my factory NBT2 from my 2015 228i xDrive, the GPS Arial on the head unit had nothing connected to it.
It seems like the GPS Signal comes from the Ethernet connection on the ATM module. Have you tried disabling these parameters? They were set to Aktiv on mine. Perhaps it will allow you to fail over to the main antenna on the head unit instead.
ADAS_GPS Nicht_Aktiv
GPS_FROM_NAVI Nicht_Akitv
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      09-17-2015, 11:22 PM   #5
juniortabak
47
Drives: M135i
Thanks,
try that but no go
      09-30-2015, 11:56 PM   #6
juniortabak
47
Drives: M135i
Originally Posted by juniortabak View Post
Thanks,
try that but no go
Solved!!!!
      10-04-2015, 01:49 PM   #7
dizx
dizx's Avatar
Thailand
67
Drives: 2020 G20 330e
Solved!!!!
What was the solution?
Current: 2018 X1 F48 & 2014 F20 116i. Before: 2009 BMW E90 320d LCI, 2008 E92 M3 &
      10-04-2015, 03:56 PM   #8
juniortabak
47
Drives: M135i
Coding, i will ask my friend that fix it.
He his not coding with E-sys but i will try to get some information
No Telemtic box just Coding.
      10-06-2015, 02:59 PM   #9
steve@codemybimmer
Hong Kong
665
Glad you got it working. If you can find out what he did, that would be great!
      10-06-2015, 03:12 PM   #10
juniortabak
47
Drives: M135i
I promise that i will do my best he is not the guy that like to talk!!!
but i can tell you that he is the only one that could solve it.
i just so one more retrofit link below:
I want BMW Live and Internet very very very......
      10-06-2015, 03:13 PM   #11
steve@codemybimmer
Hong Kong
665
I saw this video on YouTube the other day. Didn't realize that it was your car.
I'm guessing that the unit originally came from an i3 looking at the interface. Either that or he used an i3's FA to flash the NBT2.
      10-06-2015, 03:22 PM   #12
juniortabak
47
Drives: M135i
Its not my Car
If you want i can post my car.
I have a M135 2015 LCI did some more changes.
      10-06-2015, 03:24 PM   #13
juniortabak
47
Drives: M135i
Technically you can change the UI but for me just the RR works and its looks ugly.
      10-08-2015, 06:40 AM   #14
juniortabak
47
Drives: M135i
for the Solution you need to contact:
https://www.facebook.com/Componentltd?fref=ts
The best in the BIZ
      01-09-2016, 06:36 PM   #15
ID6
Drives: motorcycle
For others with the same issue:
NBT EVO gets GPS position over ethernet now from the ATM module. If you are retrofitting a used EVO from a car which originally had an ATM module, you need to change coding in the EVO headunit to use the internal GPS gyro. NBT EVO exists both with, and without ATM module on ethernet/OABR.
This change should be standard with any EVO retrofit into a car with a TCB. (NBT cars)
      01-10-2016, 06:04 AM   #16
juniortabak
47
Drives: M135i
Can you post some lines to see how it's made?
      01-12-2016, 01:54 AM   #17
dishy
Drives: M135i
I hate it when a discussion goes forward and the OP goes "I fixed it!" But wont give any details. Oh well,
      01-12-2016, 02:16 AM   #18
juniortabak
47
Drives: M135i
I did not fix it!!!! It's a workshop that would not let me know how!! And I respect it very much!!!
I am very curious how he did it!!!
      03-29-2016, 10:12 AM   #19
sal00
sal00's Avatar
Drives: F30 320D Auto Estoril Blue
Hi,
I own a 2013 f21 116d sport. It comes with the standard non sat nav display unit. I was wondering if the 2015 nbt evo sat nav 8.8' work in my car ?
      05-12-2016, 10:29 PM   #20
ID6
Drives: motorcycle
The 8.8" evo screen will work Only with EVO...the voltage supply to the screen is different between evo and nbt.
      05-12-2016, 10:34 PM   #21
ID6
Drives: motorcycle
Just FDL code the EVO for gps via shark fin instead of atm. You need to code the evo as if it is in a car destined for a country with no telematics/backend connection to BMW.
      05-17-2016, 07:59 AM   #22
VitaminXX
Drives: BMW E39 525i
Do you know the parameters that set te GPS via shark fin? I have trouble to get the GPS signal.
