05-15-2018, 10:05 AM | #1 |
Rep 16
300bhp Bmw F20 N13
So i have a BMW F20 116i
At the moment the following changes have been done: Stage 1 Remap - 220 BHP 310NM Since then i have been prepping the car for stage 2 i have fitted the OEM BMW m135i Intercooler a Pipercross panel filter but heres my query, my car just had a service and needs spark plugs, so as i know i am going to be pushing more power, i want to future proof my car and make sure i get the correct spark plugs. Many people say m135i spark plugs are the ones others say NGK ? what is the best path to go down ? Following this, Ignition Coils - Should i upgrade to m135i Ignition coils or is this a waste ? reliability is a must on my build, once stage 2 map is carried out i plan on getting a turbo custom fab or go meth injection. i really cant find any turbos at all for the N13, my only theory is getting a turbo from a 120i N20 and seeing if it could be custom fabricated to fit on the N13 ???? i am guessing a custom down pipe will then also be needed. either way i will be going meth injection with or without a turbo upgrade. Any tuners recommended for meth injection ??? Like i said - 300BHP is my target may sound unrealistic but considering stage 2 should be running 240-250bhp, if i did get a turbo upgrade maybe 260bhp (im probably dreaming) then meth injection is 20% more power 250 + 20% = 300 BHP !!!! On paper this really is a recipe for a animal! i plan on getting m135i brakes, as stopping is just as important as the HP figure. Any advice ???? has anyone got to 300bhp yet ? and all this on a humble 116i. |
05-15-2018, 02:26 PM | #2 |
Rep 104
peugeot has done it. RCZ R and current 308 GTI both have 270 hp peak power. you might wanna take a look at their setup since the engine blocks are the same.
engine codes for peugeot group: EP6FDTX - 205/208/210 hp 1.6l THP Peugeot 208 GTi EP6FDTR - 250/270 hp 1.6l THP Peugeot 308 GTi EP6CDTR - 270 hp 1.6l THP Peugeot RCZ |
05-15-2018, 02:41 PM | #3 |
Rep 1,340
05-15-2018, 03:26 PM | #4 | |
Rep 104
MINI uses a variant of Prince engine too. Cooper JCW has stock power of 211hp and produces approximately 266hp at stage 1 tune. not quite sure if such high output (300hp) is achievable on N13 engine, however 250ish hp sounds doable. |
05-16-2018, 01:35 AM | #6 | |
Rep 16
because another thing is.... 250bhp is all good but will the stock turbo take that power ? i really need a better turbo to keep reliability to a maximum. |
05-16-2018, 02:00 AM | #7 |
Rep 58
Not sure if is it the same engine, but I had a THP and isnt the most realiable engine.
For the power your looking for you should get forged pistons, rods and a big turbo like garret gt28 or similar
120d Xdrive //M 2014
05-16-2018, 02:06 AM | #8 |
Rep 58
Not always is like that. Not every engine reacs same with meth.
To get much more power using meth inj, you will have to set a high timming setup and 100% meth (I mean, the injection ) Its a bit risky, because if you have some failure in the meth pump, your tank is empty or whatever is a blow up
05-16-2018, 02:11 AM | #9 |
Rep 58
this might be useful https://www.etuners.gr/peugeot-citro...servicing-101/
Mini w/ turbo upgrade https://www.etuners.gr/mini-cooper-s...t-jcw-stage-3/ peugeot 308 w/ hydrid turbo upgrade https://www.etuners.gr/peugeot-308-g...-98ron-260bhp/ peugeot 207 w/ EFR6258 turbo https://www.etuners.gr/peugeot-207-thp-stagexxx-100ron/ Etuners are probably the best thp tuners in the word, they have a lot of experience with those engines
05-16-2018, 02:14 AM | #10 | |
Rep 16
the AEM kit also has a light showing when empty etc... |
05-16-2018, 02:23 AM | #11 | |
Rep 58
Yes sure, but if something happens.... booom! Different story is using meth for cooling down your intake
05-16-2018, 03:31 AM | #14 | |
Rep 58
Because I blowed it up using 100%meth with a AEM meth kit and a TD04 turbo from subaru My advice will be to be pretty careful with the chain tensioner (it fails all the time, so check it before doing any upgrade) and go for a meth kit but without a agressive timming map. With a JCW turbo, plug and play you gonna have a pretty fast car without touching internals (250/260hp). If you want more, start thinking about forged pistons and rods and a GT28, GTX or TD05 turbo. PD: No matter what, get a good tuner
05-16-2018, 04:07 AM | #16 | |
Rep 16
how much will forged pistons and rods cost ££££ |
06-16-2018, 01:51 PM | #18 |
Rep 29
Hey man any update on this yet? I'm willing to make my 114i (same engine) push more power, I will follow this thread and see what ya'll come up with
2017 - 2020: BMW F20 114i 2013
2019 - now: BMW F32 435i 2015 |
08-06-2018, 12:14 AM | #19 |
Rep 30
seriously under what scope you guys compare the FWD to RWD engine capabilities?
300 on the prince not happening with out changing the internals (not pistons only) anything above 350nm on the N13 the block breaks!!!! Coils i had answer this to you on another post n13 n20 and n55 use the same coils! SP either from the NGK of the N20 or N55 without messing about with the gap. Cooler get rid of the N55 cooler and upgrade to a Wangner one or similar volume. The 135m brakes? you mean the sport blue brakes found on all models! |
01-10-2019, 04:02 PM | #21 |
Rep 2
I own a stage 2 bmw 116i, intake, intercooler, decat and full turbo back 3 inch exhaust. It was mapped and did 245hp on the dyno. I've been looking very deep into getting a bigger turbo but for the gain there is no point unless you go forged internals.
The N13b16a engine will not take anymore then around 270/280hp before internals start giving way. The n13 engine shares pretty much all the internals from the n18 engine that's in the r56 Cooper S, and with a bigger turbo they limit them on stock internals to no more then 270/280hp. The n13 in the 116i will easy go over 300hp with a bigger turbo and easy over 400hp with meth. But only on forged internals. Stock would give way straight away. I've done a loud of research into the mini JCW turbo to see if it would fit straight bolt on to the 116i and no it won't it's not a direct replacement! The turbo sits the opposite way and the exhaust housing of the jcw turbo is different to the n13 turbo. There's a company doing a hybrid turbo for the n13 engine and with a bone stock car there pushing 222hp at the wheels, so around the 265hp at engine mark. For the money I wouldn't go bigger turbo on the n13 engine unless you have the money to do the internals. Forged internals= Rods, pistons, Cams, head studs and then bigger turbo would easily see 350-400hp on the n13 engine depending on turbo size. 500hp is achievable but will need engine head work, big turbo and pure meth. |
04-14-2019, 03:21 PM | #22 | |
Rep 24
Tags |
116i, 300bhp |
