BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > BMW E-diff vs Quaife ATB
      04-03-2018, 11:26 PM   #1
harkes
harkes's Avatar
China
1078
Exclamation BMW E-diff vs Quaife ATB
Could you guess the outcome? Please let me know what you think about the video
(A Dane in China)
amw896582.50
      04-04-2018, 01:33 AM   #2
HercPehl
Drives: F20 125i
The 0-100 is not the most interesting when purchasing a LSD but the fun is in going sideways on the corners. A test on track looking at time laps would had probably been a better comparison.
      04-04-2018, 10:25 AM   #3
My comments:
- I don't think the e-diff is enabled in traction mode, only in DSC Off mode. At least that is what the BMW documentation and manuals say. If you had selected Sport+, you would have gotten traction mode with the engine response in sport mode.
- My experience is that the best 0-100 times are set on cold days. The engine performance drops noticeably with increased heat.
- Less wheelspin is not always an advantage in such tests.
As an example, I used to have a 1990 BMW E30 318iS. The factory claimed 0-100 km/h in 9.9 seconds. I did a 7.9 second run (GPS logged) with studless winter tyres and limited slip differential on a very cold winter day, with lots of wheelspin. I think the engine was over 5000 RPM the entire run because of tyre slip.
      04-04-2018, 01:32 PM   #4
No one
Drives: F21 118i
Well:
  • I like the traffic;
  • The bolts and nuts are what I'd expect from the exhaust pipes with that sound;
  • The worker tightens bolts in a wrong sequence;
  • I negotiate prices beforehand (to save myself the burden of proving they should've);
  • I wonder if he had allowed to take his wheel away without a proof of return (a paper order that should've included the price too, perhaps);
  • "The one who knows little wonders a lot." (a Chinese proverb?)
Ultimate acceleration appears a matter of power/grip balance. If you wish to play it simple , make sure you don't have much power: all you have to do is floor it (keep the revs high, more precisely) then - you won't have too much wheelspin anyway. Driving a powerful car is more challenging: you can overwhelm your tires still standing where you are.
To measure lots of wheelspin acceleration I'd suggest the speedometer.
      04-05-2018, 05:13 AM   #5
harkes
harkes's Avatar
China
1078
I have 850km to the nearest racetrack so this is the level of testing I could do within reason
We can all agree that the biggest difference should be seen in out-of-corner acceleration and sideways stability, but to measure that with high repeatability and reliable data...I dont know if that would be anything else than subjective.
Waiting for some rain so I can do a skid comparison with the E-diff:
(A Dane in China)
      04-05-2018, 05:21 AM   #6
harkes
harkes's Avatar
China
1078
My comments:
E-diff is always enabled. In four years owning the car I have never once experienced only the inner tire spinning. I have plenty of power (440 crank in the video) so cold or not does not matter - you can also see in the video the TC is still at work at quite high speeds.
(A Dane in China)
      04-05-2018, 07:14 AM   #7
HercPehl
Drives: F20 125i
700 for me, i feel you
      04-05-2018, 07:30 AM   #8
But the traction control will probably do something similar, trying to stop all sorts of wheelspin. In traction mode (or sport+), the traction control is pretty much disabled, but stability control is still at work, cutting in if it thinks the car is starting to be unstable.
BMW says the e-diff is only enabled in DSC Off, but I guess that could be interpreted in different ways. Maybe they mean that everything is off, except for the fake differential brake.
harkes1078.00
      04-05-2018, 04:17 PM   #9
No one
Drives: F21 118i
So it's harkes himself (repainted without notice). I might need to elaborate my impression from the video then.
The topic has been discussed here too many times to mention. ovekvam, in particular, has written quite a book spread over those threads. Here's just one for example: Open-diff vs. E-diff- vs LSD (F20 related).
What is "E-diff"? DSC is a complex system (this document, page #18, looks kindly quoted) working with all the wheels (brakes) and the engine (power):
. "Quaife Helical" is what it is - an LSD. How can you compare those? Put the simplest, "Quaife Helical" is what helps to drift, DSC(/DTC) taken as "E-diff" is what prevents drifting (still failing to overcome the laws of physics). When you choose DTC to "allow the wheels to spin" it is like you disable LSD to some extent. So taking as "E-Diff" the Active Differential Brake (ADB-Sport) feature (activated "When DSC mode is off" - does that make a bit of sense already?) looks the only correct approach to challenge "Quaife Helical" (which needs not DSC "wrapper" to show itself either, perhaps).
How do you know? You heard the left wheel and checked the right you say.
When DTC "E-diff" steps in the instrument indicator flashes. Quaife Helical is always there (when it's there) and it's claimed to step in faster even than the ADB ("DSC OFF") "E-diff".
Regarding the 0.1 second - how much does Quaife Helical weigh to add to traction?
      04-07-2018, 08:18 AM   #10
harkes
harkes's Avatar
China
1078
(A Dane in China)
      04-07-2018, 09:55 AM   #11
harkes
harkes's Avatar
China
1078
Not sure where to begin with a reply here. Just trying to compare DSC off with factory E-diff and DSC off with Quaife. I am very sure that DSC off is exactly that meaning that DSC and DTC are both diabled. Look at the video. How would I be able to drift the car with both systems active..? E-diff, for me, is the function that via the brakes makes it possible for an open diff to mimic that of a mechanical differential.
Yes, the baby blue wrap is now off the car. Back to factory white
(A Dane in China)
      04-07-2018, 10:53 AM   #12
The Quaife is a TorSen type differential brake, and my impression is that one of their main drawbacks is that they struggle to get the locking going when one wheel has no traction. That could be when one wheel is on ice, or in the air. In your application, you still have the ediff in addition to the Quaife. That means that if the Quaife has issues with too limited traction, the ediff will provide that by braking the spinning wheel. It should be a winning combination, and seems to work very well in your video.
      04-07-2018, 11:40 AM   #13
No one
Drives: F21 118i
"Not even DSC can overcome the laws of physics." Yes, I had to look at the video again (Congratulations! ). When you're drifting the indicator does not flash so I guess it's DSC OFF (which is/appears correct) rather than DTC (traction) you claim you choose in the first video.
What I meant you had shown neither knowledge of driving modes nor understanding of differential locking practical purpose as we knew them here. Also, you seemed to further insist DTC included "E-diff" because it used the same technology. I thought it was like pointless.
Now you seem to put it correctly to my understanding and ovekvam knows better.
Michelin Pilot Sport provide amazing grip even worn off! I suffer plenty of wheelspin with my winter runflats and quite some with my summer ones having less than a half of your extended power (watching the first video I felt like the chassis hardly coped ).
      04-07-2018, 11:55 AM   #14
Judging by the first video from harkes, it does indeed look like there is an ediff feature enabled, as wheelspin is allowed, but both rear wheels seem to spin very evenly. I have tried quite a lot to test it on my own F20, but haven't really managed to find a good way of doing it. BMW documentation indicates that ediff is only enabled with DSC Off, but maybe that is not correct. I am still not convinced if it is enabled or not in Sport+ and DTC mode.
The ediff is very noticeable in corners when it intervenes, but I can't really tell what it is doing when driving straight. Testing corners with DTC or Sport+ causes the stability control to cut in.
      04-07-2018, 01:00 PM   #15
No one
Drives: F21 118i
But ediff is what works when the wheels don't spin evenly, assisting the rotation of the car, isn't it? In the first video I couldn't notice any fishtailing I'm so familiar with driving in Sport+ in winter. I even had to go down to DTC recently as it's quite uncomfortable to find the car suddenly pointing at the oncoming lane (when in the leftmost, right-hand traffic). Luckily no thrust! And isn't that an indication of no ediff involved (only a skid so I can take my time to correct)?
In DTC and Sport+ there's a delay before the stability control cuts in. You get wheelspin (heard, but not always) and fishtailing (sometimes) before that happens (the indicator starts to flash). In some test video I recall a statement only a limited skid angle is allowed thus you can not spin around (unless that physics again).
I've just watched a TorSen explanation video (failed to get why only one of the connected wheels can spin the other, not vice versa, I'll think about it ), read the comment and wondered if I really did it right relying on DSC OFF to move a stuck car caring not to have the steering wheel always turned...
      04-07-2018, 01:24 PM   #16
DTC and Sport+ are supposed to leave some wiggle room for the driver, but it is not possible to do any drifting. The car waits a bit to see if the driver corrects the car, and if not, it cuts in to spoil the fun. You are however allowed to spin the wheels quite a lot in a straight line, which can be practical in snow, to dig the tyres into the surface.
In a corner, it is usually the inside wheel that is unloaded, and starts spinning first. When the ediff intervenes, it will brake the inside wheel. This feels almost like somebody attaches a cable to the front of the car, and pulls it towards the center of the corner, as the uneven brake force rotates the car into the corner and kills the usual understeer you would get with an open differential. As harkes shows, it is not nearly as smooth as a mechanical LSD, but it does get the job done somehow.
The trick with the TorSen differential is that the screw gearing is so high that it can only transfer torque one way, not the other. It is the same thing as the screw in many car jacks. The weight of the car does not turn the handle, but turning the handle lifts the car.
The one advantage an open differential has, is that it always distributes the torque 50/50, even if that means transferring almost no torque at all. It makes the car very stable in a straight line, so that the rear doesn't step out. It sacrifices traction for stability. It would make sense for BMW to act like that with DSC enabled, but maybe not in DTC and Sport+.
No one1041.50
harkes1078.00
      04-07-2018, 01:43 PM   #17
No one
Drives: F21 118i
Thanks for the explanation! They so often omit the most important for understanding.
      04-08-2018, 01:28 AM   #18
harkes
harkes's Avatar
China
1078
Good point. One of my next tests will be with one wheel in the air to see what happens and I think you are right here. Because of the E-diff I will have a "Quaife+" that will also work with zero traction on one wheel
(A Dane in China)
      04-08-2018, 01:43 AM   #19
harkes
harkes's Avatar
China
1078
Maybe read a little more or just go have some fun with the car to understand the systems.
One video is trying to compare dry traction, and the two others wet operation - if that was unclear.
(A Dane in China)
