BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 DSC light
      10-23-2017, 07:53 PM   #1
Keith Moy
Drives: 2013 F20 118i
F20 DSC light
Hi All,
I have a 2013 F20 118i and the DSC warning comes up sometime recently. I plugged my computer and got the below fault codes
107A81 Throttle Valve, spring closing test: Malfunction
4809AB DSC: Undervoltage in Vehicle
8040F5 Ring aerial: Aerial fault
D02D58 Signal (wheel torque powertrain 1, 41.3.4) invalid, transmitter DME
D35A57 ICM interface (longitudinal acceleration, centre of gravity, ID: 0X199) Signal invalid
D36D58 Signal (wheel torque, pwoer train 1, 0x08F) invalid, transmitter DME
Have changed a new battery, got it registered already.
Alternator seems work too.
Problem still the there.
Any ideas?
Thanks and regards,
Keith
      11-02-2017, 04:28 PM   #2
All of these could have been caused by a temporary battery issue. Maybe the best way to find the issue is to clear all the faults, and wait until it happens again, and then check for fault codes.
      11-06-2017, 07:20 PM   #3
Keith Moy
Looks like is the problem of the DSC control unit. Can it be replaced by a used one? Need to change the VIN? By e-sys?
      06-24-2023, 12:45 PM   #4
charleshwy
Drives: 118i M Sport
May I know how did you solve the issue. I have got very similar codes when I did a scan on my 118i.
      06-30-2023, 03:55 AM   #5
IJO
Drives: BMW 116I F20
That was from 6years ago, so maybe you'll never hear from them.
How old is your battery?
      07-04-2023, 01:47 AM   #6
charleshwy
2 years old. It says 87% on Bimmerlink.
      07-04-2023, 01:53 AM   #7
charleshwy
I have got these codes on my scan, looks like the throttle body causes the problem.
