BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > M135i Exhaust Flap At Startup
      07-11-2021, 10:02 AM   #1
RRP3
RRP3
Portugal
Drives: 2013 BMW M135i
I have a 2013 M135i.
I must be the only person on the planet that wants my exhaust valve closed during startup. Everything I see when I google it is everyone wants theirs open.
Is there a way, Bimmercode?, to have the exhaust flap closed when the engine cold starts?
Thanks,
Richard
      07-11-2021, 10:40 AM   #2
No one
Drives: F21 118i
https://f20.1addicts.com/forums/show...highlight=flap
RRP30.00
      07-11-2021, 10:56 AM   #3
RRP3
RRP3
Portugal
Thanks so much for the quick and great reply!!!
      07-22-2021, 12:39 AM   #4
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
Your exhaust valve is closed during a cold start, and this is not what makes the sound volume higher (no back pressure either)
It is an increase in speed and air injection so that your catalyst heats up faster that occurs, according to anti-pollution standards.
So the only way to avoid the "BMW cold start" is to encode the DME.
      09-24-2021, 07:54 AM   #5
idemsisvoje
Drives: M140i xDrive
I was also thinking about disabling it on my M140i, but I've seen a few people on FB forum having issues after they disabled the cold start procedure.
      09-24-2021, 12:05 PM   #6
goonerzak
goonerzak's Avatar
Drives: BMW M135i
It wouldn't be so bad if it only did it on an actual cold start, but it does it on every single start hot or cold AFAIK.
      09-24-2021, 12:45 PM   #7
F20_M135i
France
101
This is not normal and your DME may present a problem, because it is only from a certain temperature of the catalyst that the cold start order is sent.
      09-25-2021, 09:35 AM   #8
goonerzak
goonerzak's Avatar
Drives: BMW M135i
Depends on what car you have, N55 will only do it on cold start, B58 will do it every start up regardless
      09-25-2021, 05:59 PM   #9
gbak02
Drives: M135i
i done it , deactivated permanently fully open , unplug it and safety tied at the back of the bumper .
no faults or indications after that .
